DFW Torx Bolt Removal Help!
Juben
Chattanooga, TN
Justin
2015 EcoBoost Mustang (AT) w/PP
Removing the counter weight (what jbailer is referring to) and tacking the torx bit to it is going to be the easiest method. Trust me on this one. I tried a little bit of everything except for cutting the heatshield and I didn't want to do that because it still doesn't remedy the problem.
Redcruzer
Redwood City
2015 eco boost premium convertible, Ruby red
If you can get a dremel in there with a cut off disk you can cut a slot and use a screwdriver to remove it.
Jasber
Jasber
Corinth, TX
Jason
2015 Mustang Ecoboost Ingot Silver
Thanks to everyone for all your tips and advice! Gonna give it a go again tomorrow night! Wish me luck!
PewterCam
Chicago Suburbs
2001 Z28 Camaro and 2015 Ecoboost Mustang
I mangled that bolt getting it out on my car and replaced it with a hex headed bolt I had laying around. I have no idea what thread it is or anything. I have a ton of bolts from various cars saved and had one that fit.
jbailer
Joe
That is a smart idea. I have a bunch of bolts laying around too but couldn't find one that fit. Stupid me, I bought another of the same bolt from Ford for like $8 or something (can't remember exactly). What I should have done is gone to the hardware store and bought a regular bolt. Mine wasn't totally mangled, just a little bit but enough I didn't want to put it back in.
Jasber
Jasber
Corinth, TX
Jason
Oh I'll definitely be putting a hex head in once I get the little f%%^* out!
perfweld
Northern CA
Why dont you just take the Turbo off the car, then mess with the bolt. I take my turbo off with the cover on still.
jbailer
Joe
The turbo being on or off the car wouldn't impact access to the lower bolt on the heat shield.
perfweld
Northern CA
Sure it would help, the bolt would be right in front of you on the bench verses laying over the fender and underneath the turbo.
higdominator
Central Oklahoma
2016 GT PPP
That may just add more to the frustration re: coolant fountain.
I would try something like these. Just find one that almost fits on the bolt head, give it a tap with a hammer/heavy tool, attach ratchet without moving too and start wrenching. Use a quick motion to help it bite. Once it does it'll come right out. They have worked for me well in the past (Don't get these "squared" ones, get the round/helical sharp ones from Orielly's:
Otherwise pick your redneck engineering removal of choice: ajax/wet sand; weld a bit, fill head with JB weld, insert bit, try it the next day; cut bolt head off, remove shield, grab stud with locking pliers, and so on and so forth....
Jasber
Jasber
Corinth, TX
Jason
I'm going to try the torx plus tomorrow. If that's a no go, remove canister and try to weld again. If all else fails - I'm going redneck!
Jasber
Jasber
Corinth, TX
Jason
Went redneck. Cut the damn heat shield near the bottom to solve the problem. Finally got the wastegate on and tune loaded. Now it time to datalog!!!
bestbacon
Markham
EB 2015 Mustang DIB
Damn I didn't respond fast enough, I was just about to say that if you jacked up the front passenger side and took off the wheel that you could go under and use an extractor to get it off too. Just make sure you use some lubricant and all should be well. In all honesty though I don't even know why they bothered to randomly put one t30 torx bit at one of the hardest to reach locations...
papinist
The Italian Pony
Tuscany, Italy
Stefano
Mustang EcoBoost MT Race Red EURO - NO MORE
what's the name for these?
