Deatschwerks injector upgrade?
KrisR
White Bear Lake, MN
2015 Mustang Ecoboost PP 50th Premium
daltron
Rowing All Day
California
Jonathan
2016 GT PP
If you need 1700cc injectors then you have a serious built motor.
In general I would go with Ford for say the 47lber's or if I needed more then ID.
Juben
Chattanooga, TN
Justin
2015 EcoBoost Mustang (AT) w/PP
The HPFP simply can't flow the volume needed for the stock injectors (on greater than E30) much less larger ones. It's kind of like having a water pump that maxes out at 100 GPM. If there's not enough flow for a 2" pipe then a larger 3" wouldn't do anything to offer a benefit(s). If the injector duty cycle (IDC) was high on the stock injectors, larger ones would help with that, but otherwise, until a improved HPFP comes out we won't be needing these.
Ron@cp-e
MD
whoosh
2015 EBM
a birdy told me that these flow enough to empty out the fuel rail at WOT
in other words HPFP can't keep up....
Weather Man
Persistance is a Bitch
MN
2015 I4 T Prem Auto
BEEF did not sound enthused when he tested them Kris.
v8440
AL
2016 gt
It seems that at this point, bigger injectors are a sure way to increase an ecoboost's performance through weight reduction. This occurs via lightening of the owner's wallet.
KrisR
White Bear Lake, MN
Gotcha. I wasn't sure on what the injector duty cycle was at when the HPFP maxed out. I've never logged IDC.
Tune+
St. Paul, MN
www.facebook.com
Adam
2015 Ecoboost Mustang Automatic
:frusty::frusty::frusty::frusty::frusty::frusty:
wildsailor
This Club for me?
SE Michigan
2015 Ecoboost
Don't need them/not necessary. PI via aux injection is the ticket.
I think aux injection may solve the issue with oil buildup on the valves as well.
