Deatschwerks Injector Install...
EcoBOSS
Tejas!
2015 EcoBoost Premium, PP, 50th, RR
Inquiring minds and all...
Who's got what?
Anyone do these?
Tips on pulling the fuel rail?
Couldn't break the fitting loose from the HPFP, so I stopped.
Thx
EcoBOSS
Tejas!
No, but if it is a standard RH thread, I'd be willing to try...
EcoBOSS
Tejas!
No one?
Not encouraging... :(
Chef jpd
Brooklyn, NY
EcoBOSS
Tejas!
High pressure fuel line that spews gasoline as long as the engine is turning?
I find it hard to believe someone on here doesn't have the service procedure on this...
Ford probably recommends replacing the line if the fittings are turned...
Rod Schneider
Ball Ground, GA
Rod
2016 Mustang EcoBoost
Per the 2016 Service Manual: The high pressure fuel hose must be replaced whenever it has been loosened. The torque on the fittings is: 1st stage, 62 inch/pounds. 2nd stage, 133 inch/pounds. 3rd stage, 30 degrees. If you use a crows foot on a torque wrench, beware that the change in the effective length of the torque wrench will need to be accounted for to achieve accurate torque settings....
