shogun32
- Feb 8, 2019
- Northern VA
- Matt
- '19 GT/PP, '23 GB Mach1, '12 Audi S5 (v8+6mt)
- Vehicle Showcase
- 2
again, nothing on the ECU gives a sigle damn what size tires are on the front OR the back. You make it sound as if the computer will go ape and lose it's mind if you change the rolling diameter of the tires. NO NO NO and NO! the computer doesn't give a damn what size is on a rim or even it's compound and grip characteristics.HP has 305/30 R19 in the front so if someone put 275/40 R19 in the FRONT, there would be 6% diameter difference which is way outside of accepted tolerance.
Sure it might have a table that describes the Cup2 boundary conditions (eg. maximum brake system pressure) but when the abs sensors trip, it throws those assumptions out the window and deals with the fact that the all-season 285/35 that's is actually on the rim is giving up.
Nobody is stupid enough to write an ABS module that assumes the car has the same tires or wheel sizes as it came with new from the factory. I can replace my 27" tires with 22" and the computer DOES NOT CARE.
