Correct your speedometer error - no flash or tune required
Bespinoza66
Los Angeles, CA
2016 automatic 5.0, 4.09 differential
And there's no way I know of to check that the PCM relearn was successful, unless your DTC goes away and then you know for sure.
Yeah, forscan seems to be the only way to know without going through a much more expensive service
Spart
Midwest
17 GT350
I don't think FORScan can read the values that the PCM relearns during the procedure. Hence, no way to verify.
Bespinoza66
Los Angeles, CA
As long as the code goes away and the car doesn't explode, it may be safe to assume it does lol
Spart
Midwest
17 GT350
Right. But what I'm saying is, if the relearn was maybe successful and something else may be going awry, you have no way to confirm what the problem is when you do still have a DTC present.
FreePenguin
Ohio
Donald
17 mustang
I am going from 255/40/19 on 19 to 275/40/19 tomorrow on 9.5. I am going to attempt to change the one line of code for the change, is it still safe to do now a days? following the guide in original line or has there been negative failures?
im not doing transmission / ratio changes. Just the tire size change.
FreePenguin
Ohio
Donald
17 mustang
I read there’s something like 4% off
If not I will disregard interested to hear opinion, I will of course compare to gps first before I tinker
SAY WHAT
Tim
2016 mustang Gt
you will only be off like 2 mph at 80mph anything under will only be 1. Tbh performance pack cars run 275/40/19 in the rear where the speed measured.
FreePenguin
Ohio
Donald
17 mustang
im a non PP ecoboost, but if its only off by like 1 mph, I am not going to bother, in fact I kinda like a little 1mph cushion at 70mph (our speed limit is 65-70) but if it was like 4mph id of had to change. if I go 285/35/19 will it be the same as well?
reason I ask is im test fitting 275 on my wheels today to see how they look, if doesn't give the curb protection I need for rim, may add 285 instead.
Spart
Midwest
17 GT350
That's not how it works.
Going from 255/40R19 to 275/40R19 is a 2.3% gain in circumference. When you go up in circumference, your speedometer reads slower, not faster.
When your speedometer tells you you're doing 70, you'll actually be doing 71.6 or so, not 69 like you're thinking.
FreePenguin
Ohio
Donald
17 mustang
then I will be changing my calibration, I stick my speedo right on 70mph for cruise, so the question, by finding my new value via hexadecimal and changing that 1 line of code, its been pretty foolproof right? no engine codes/issues? I know I read all the pages of this and it seemed people changing the parameters for the gearing/transmission was having DCT's etc. but I dont mind doing the forescan change (I use forescan a lot and takes 2 seconds) just dont want issues to pop up with non erasable codes/or popping other issues like gimp mode
Spart
Midwest
17 GT350
You'll absolutely get a DTC if you don't follow the instructions and do a PCM relearn after setting the size in the BCM.
