Correct 20 inch wheel choice (sizes)
1024GT
Houston
I have the 20 inch foundry wheels and I think I want to stagger.
Would this be right?
275 35 20 and 305 30 20 ...I want to keep the same diameter as much as feasible. I think the 285 ratio will be a bit more off.
Would this set up be fine on 20X10 wheels square?
Thanks!
Road Dog
Really Smart Member
St Petersburg, FL
Carl
2016 Mustang GT Convertible
You will probably be just fine, the 275 list as 27.6" tall and the 305 list as 27.2" tall. Speedo will be off by a +tenth of a MPH. You might want to use a 20 X 11 wheel for the rears though.
DRKHORS
Mark
'18 F150, '23 Mustang GT
Thanks!
Personally I wouldn't do a 275/35 and 305/30 set up. You're going to be able to see the difference in sidewall height between the two and will look out of place have a fatter sidewall up front than out rear.
Check your speedo against GPS to see where it's at from factory. Reason I say this is I am running 315/35's and my speedo is only off 2mph, which means it must have been set slightly fast from factory.
c_reber
REB3R
LV, NV
`16 Mustang GT (PP), `15 X5 50i
Are you putting these tires on the factory wheels? Or you are buying new 20x10" wheels?
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
Are you going with a lighter stronger aftermarket wheel or you sticking with factory foundry wheels and widening them?
1024GT
1024GT
Houston
I think I have settled on the Niche Essen wheel. I'm pretty sure I'll stagger them but I'm still debating 9 or 10 in front. Something I didn't consider is running 10.5/11 in the rear. I don't want the sidewalks to be off and I don't want that meaty looking rear tire. Just wanna make sure I know what I'll be getting in the mail from you pretty much when I go for it lol
