peppersam740
Has anyone put on a Haden or Four Seasons adjustable temp fan switch ?
Our fan has a logic controller IIRC which isn't a simple off/low/hi switch. You can control fan speed and temperature activation in your tune.Has anyone put on a Haden or Four Seasons adjustable temp fan switch ?
Cylinder head temp is usually around 5* higher than coolant temp. I don't recommend the using that sensor as a switch though, you would have to bypass the controller on the fan and send the current straight to the motor from the battery via relay. While possible, It would be cheaper to just tune the car.Thanks for your input. I don't have a tune on the car, waiting for the warranty to expire. My temps climb when waiting at red lights. I think you can adjust what temp you want the fans to come on with these units. I just don't like seeing the temps going 215 and over.
Lund>VMP>Palm Beach Dyno, either of those 3 would get you taken care of, but they will all cost about the same.What tuner would you recommend. I have read good and bad on all of them.
