Cold and summer only don't mix
plc268
Central Texas
Patrick
2015 Mustang GT Premium Race Red
One of the first reviews on tire rack for the Pilot 4S says they turned into "hockey pucks" in the cold.
Again, I'll just feel better with the all seasons vs. chancing anything with the summer only.
Thanks
I drove my pilot 4s in 15 degree weather and they did just fine. Just got to be mindful that the traction will be worse, but they were fine.
ahl395
Allan
I went for a ride in a friends supercharged car with MPSS on it, held great even at WOT in ~25F weather. I was impressed. [MENTION=23692]cpelaez1[/MENTION]
ahl395
Allan
Emt1581
PA
2017 Magnetic Mustang GT w/PP & TurboBooster Seat
Are the DWS06 the consensus for an all-season replacement for the P-Zeros?
~$900 for a replacement is pricey, but is it worth it over other cheaper tires?
That's what I'll be getting. Walmart and Tire Rack are only a buck or two different in price on them.
However, I'm not sure which 19 is optimal for the SVE Drift wheels I plan on getting. I have walmart (online) suggesting one size, Tire Rack another, and then my Ford service center yet another....
...what specific DWS 06 did ya'll go with size-wise?
Thanks!
Bluemustang
2015 Mustang Base GT
Thanks!
Ask [MENTION=10281]BmacIL[/MENTION]
I believe he has the SVE drift 19s
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Thanks!
I'd recommend 275/40R19 if you never plan on lowering the car (even with a mild drop), 285/35R19 if you do ever plan to. 285/35R19 are wider but as short as your front PP tires. The speedo would be off just a little bit.
I run 275/35R19 summers on my Drifts currently. Will replace with 285/35R19 when they're done.
Emt1581
PA
Unless lowering yields some sort of significant performance increase, no real desire to.
Thanks for chiming in! :thumbsup:
fewt
Orlando
Andrew
Michelin states not to drive on them under 40 degrees, and if the temps drop to 20 or below to warm them to 40 degrees to prevent damage.
Even at 15 degrees though, they were probably more stable than PZeros.
BmacIL
Enginerd
Naperville, IL
Mild lowering with a very moderate (<5% increase) spring rate increase does definitely improve handling. The lower CG is very noticeable, and looks great! Happy to offer my thoughts in PM if you want.
plc268
Central Texas
Patrick
Well, it wasn't by choice. Typically I'll swap my stock all seasons on, but couldn't this time around.
It rarely gets that cold here in Tx anyway. I doubt I hurt the tires any.
2015Etrac
PA
Black 2016 Mustang GT Premium 401a
Look into Michelin Pilot A/S 3+ also. Bit more expensive but I really like mine.
robwlf
phila
rob
17 lightning blue pp LFP 670
i just did 285/40. michelin ss as+3,s and its a damn perfect fit . and im lowered 1 inch rear and 1.3 front.. i got 2. 255/40s in route for the front
gearhead2685
Back in North Dakota
2016 mustang
P Zeros are a garbage tire first or all.
I run Nokian Hakka R2s in the winter living in North Dakota and Firestone Firehawk Indy 500s
Best money ive spent on this car so far is taking the junk pzeros off and buying proper tires for the seasons.
1 size fits all? No such thing in North Dakota in the winter Nokians or walk and for damn sure wouldn't on P Zeros!
