Code 0128 Engine too cold.
CEHollier
Prairieville, La.
Charles
2015 GT Premium Magnetic
My car has been Lund flex tuned/JLT/Reisch 170 for over a year. Running E85 presently. Check engine light came on. Went to Auto Zone and got Code 0128 - Coolant temp below thermostat regulating temperature. At highway speeds 55-75 mph head temps ranged from 158 degrees F to 180 but mostly below 170. Ambient temp is 55 degrees F. Anyone have this with a Reisch thermostat? Considering going back to 180 thermostat.
foghat
Calgary
2015 GT w/PP
I have the reisch 170
At idle (for a number of minutes), I usually see see cylinder head temps of about 194-198F once fully warmed up - including today where ambient temp was about 14f.
While driving at highway speeds, usually see head temps of about 186-190ish, again, including today.
I'm certainly no expert and am not sure what your issue is - but not sure it is the thermostat - if it wasn't working correctly and it failed open at 170 (or at all), you would be seeing really high temps. If it opened too early (before 170) - wouldn't that just make it take longer to get up to proper operating temp? I would think you should still get there eventually. But again, I'm no expert.
Chameleon
Gold Sponsor
S550 INTERIOR DRESS UP
www.ebay.com
Warm it up.
Xavier
NH
2016 GT
I also have a Lund tune and had the Reische t-stat. It started doing the same thing after a few months. Started gradually and then eventually the engine just wouldn't reach operating temperature no matter how long I drove it. It would run a little rough and I got two codes, one like the one you got and another for a thermostat problem. I had to put the stock one back in. I think it must've gotten stuck in the open position.
EcoSwag1990
West Chester, PA
2016 Triple Yellow GT
Yea it sounds like it might be stuck open. Those temps seem way too low
Gibbo205
UK
UK 2015 Mustang & BMW E46 M3
Low temp stats are a bad idea.
Good way to thin your oil due to fuel dilution.....
Thats bad for your engine!
CEHollier
CEHollier
Prairieville, La.
Charles
Thanks guys. Has anyone changed the thermostat without draining the system? An idea I had was remove bolts from coolant tank and tilt it on its side so it won't drain out. Then open the thermostat housing and replace the stat. Then replace what ever coolant was lost I already have a gallon of Ford 50/50 mix. I may have to hose out any spillage but it seem like my idea would work. What say you guys?
foghat
Calgary
2015 GT w/PP
you don't have to drain the 'system' so to speak. There is a drain plug on the bottom passenger's side of the rad you can use to drain that. Then you can pull the stat with no loss of fluid.
I seem to remember reading you don't actually lose too much coolant if you just pull the stat without draining first (just makes a bit of a mess, obviously) - but can't remember for sure if my memory is accurate....
foghat
Calgary
2015 GT w/PP
If you do change back to a 180, I'd get in touch with Lund and see if will set the fans to turn on back at the default settings. Otherwise they are going to be running on high an awful lot.
tom_sprecher
Living Race Car Free
Marietta, GA
2016 GT Premium PP 6MT Race Red
Someone designed this engine to be run at the OEM stat temp. Remind me again what is to be gained by using a 170 stat?
CEHollier
CEHollier
Prairieville, La.
Charles
Gibbo205
UK
As I said they are a bad idea. Engines are supposed to run hot within designed specification, helps burn of fuel preventing oil dilution.
CEHollier
CEHollier
Prairieville, La.
Charles
I have gone back to the factory stat. All should be good.
Sasuketr
Chicago,IL
2015 Ingot Silver GTPP
I have the same setup. Thats one reason i wouldn't run E85 in winter conditions, especially in midwest. The car runs significantly cooler with 93 octane ranging from 180 to 185 in winter, 190 to 195 in summer. Going below 170 seems not normal but maybe possible with E85.
Sasuketr
Chicago,IL
Do you happen to have an open grill also?
