mustang_guy
- Jun 29, 2015
- United States
- it has an engine!
No, rabbit season!
Cool keep us in the loop
the lowered engine mounts are enough to fit this intake under the stock hood? how does lowering the engine affect the rest of the drivetrain geometry, like the pinion angle?
Steeds, upr, kenne bell has their ownWhich mounts are being used to lower the block?
No, rabbit season!
Where are you getting yours dyno'd and tuned?I should have dyno numbers next week. Being that it's duck season, I may not make it to the track for a bit, lol.
LOVE it! 7900 rpm shifts and this thing screams. Can't wait to get the E85 dialed in. Hopefully be done with it tomorrow.
youre running it to 7900 rpm.. i hope you have better oil pump gears..
The car is lowered on Eibach Pro Kit springs. Clearance is not affected at all even with long tubes.Can you get some pics of the clearance of the engine from the ground? Is the car lowered?
Took it to the track. Weather was meh, DA of 1000 or so. Humid. Only trapped 115. Was hoping for 118-120. Found out my intake temps were through the roof. Crazy hot. I'm currently working on a heat shield for it to keep the temps down.Results?
