Cobb AP PIDS
dr.dirty
Hesperia, CA
Scott
2017 EB Mustang PP
Hey guys im new to the 2.3 and just got my Cobb AP. What PIDs are you guys monitoring while driving on a daily basis.
DRU842
Sydney
Andrew
2017 Ecoboost Lightning Blue
Horsepower & Torque
wes936
Palm Bay Florida
2017 Ford Mustang Grabber Blue EB 6MT
Charge Air Temp
Actual A/F Ratio
Boost Pressure
Ign Correction Cyl 1 and 3
Coolant Temp or OAR learn for the last spot
PRG3k
Orlando
Turbo
Boost (Must have)
Ignition Corrections #3 (Must have)
Charge Air Temp
Oil Temp
AFR
Coolant Temp
Those are my 6
Coolant temp can be read out on the gauge cluster. Oil temp also has a readout on the cluster but the AP can give you an actual temp reading, which I like.
dr.dirty
dr.dirty
Hesperia, CA
Scott
2017 EB Mustang PP
AWESOME! As far as the ignition corrections what should i be looking for as the readings that are displayed?
PRG3k
Orlando
Turbo
Excessive negative corrections like more than 2 degrees of timing being pulled consistently. But if in California you may see that often due to the limited availability of higher octane gas. I would monitor OAR as well to make sure your ECU has learned the quality of fuel you're running in the tank. -1.0 is what you want the OAR to read, anything less and the car will pull more timing than usual.
I would read up on, or search some of those settings, readouts and terms on the forums and the COBB website to get a better understanding of how they all work together.
prostovovatt
Baltimore
2018 Orange Fury Ecoboost Manual Performance Pack
Boost (Must have)
Charge Air Temp
Oil Temp
AFR
Coolant Temp
Those are my 6
I've actually found the cluster oil temp readout is pretty close to 200F in the middle which is fine for my purposes. I try not to get into much boost until about 180F and I just memorized the arrow position for that because when I datalog it only works when I am monitoring one gauge and it has to be boost, otherwise logging fails for me.
PRG3k
Orlando
Turbo
Sounds like you have too many logging parameters selected to display anymore readouts.
prostovovatt
Baltimore
Yep that's exactly what it is. But my parameters are all the ones that my tuner (CP-e) asked for.
