Check Engine light code P0308 after new tune and CAI
stang9779
Denver
2015 GT Premium Performance Pack
I recently installed a new Steed CAI with out insert and had a tune emailed to me. After a little while my check engine light came on with code P0308. It throws after 3 to 4 cold starts. When cold starting the rpms are sporadic. They start out at 2000 RPM and move around all the way down to 1500 and all the way up to 2500. This happens for around a minute and then the motor comes down. I have done data logging and was told my fueling is where it should be. I also did a crank relearn and it did not help. I even checked to make sure that the CAI bolts are fully tight for no air leaks. Please note I'm note going to name my tuner as they are working with me. I just wanted to see if anyone else has any ideas that could help.
Volstang
Knoxville, TN
Randy
2015 Mustang GT
Search forum for that code and see if you get any hits. Good luck getting it corrected
stang9779
stang9779
Denver
I have searched to no avail. This didn't happen tell I changed my tune and CAI. I think that this happen due to my tune.
markmurfie
Hawaii
2015 Ford Mustang GT
P0308 cylinder 8 misfire. Check your plugs and all connections. Did you remove your sound tube? the rear cylinder on that side is number 8 maybe you bumped a wire loose.
stang9779
stang9779
Denver
I remove my sound tuba long time ago with my old Air Raid intake. After changing to the new intake and new to this whole issue started.
Chameleon
Gold Sponsor
S550 INTERIOR DRESS UP
www.ebay.com
Issue is probably a crank position sensor. You will need to get that fixed.
stang9779
stang9779
Denver
I did not remove the sound tube with the new install as it was removed with my old AiRaid CAI about 20k miles ago. I will check my plug wires thanks for the idea.
Chameleon
Gold Sponsor
www.ebay.com
Checking plug wires won't fix anything. This has nothing to do with that.
stang9779
stang9779
Denver
This is the first morning after the crank relearn. It maybe some what better. I will know more this after noon. The light had been throwing after lunch break on restart to drive back to work.
MikeyV
Bay Area, CA
2014 GT Premium - Brembo - Race Red
First thing I'd do it put the stock intake and tune back on and see if it's cleared.
stang9779
stang9779
Denver
Check eine light on again. I wonder if this has to do with my being at high altitude with the oversize mass air flow housing. I don't know much about Tunes but possibly their settings are not correct for my altitude.
stang9779
stang9779
Denver
I'm to the point that I would be willing to pay another tuner if they could get it right faster than this tuner is.
I think it's only a cold start issue however I'm not 100%. I sure hope this will not damage my engine.
Chameleon
Gold Sponsor
www.ebay.com
If you read above I'm pretty sure its a sensor. Take it to the dealer. Has nothing to do with the tune.
stang9779
stang9779
Denver
Why did it only do this after changing my CAI? Also why does it only throw after a cold engine start? Other than that the engine runs fine and has no symptoms.
