Chassis Stiffening importance...?
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
S550 bump stops - as with some other cars - are part of the overall suspension tune and not just for preventing shock damage.
This
GT 550
Australia
Black GT MT S550
Good article here:
http://www.superstreetonline.com/how-to/chassis-suspension/modp-1104-the-bump-stops-here
Many car manufacturers use the rear bumpstops to add to the main spring rate to support this extra load and maintain a safe handling balance and level ride.
The bumpstop also has a strong effect on transient handling events, such as turning in to a corner and applying throttle or braking in a bend. Imagine having a car nicely balanced in a long turn, then you get on the gas. The car may already be leaning on the outer bumpstops, and applying gas causes weight
to transfer to the rear and it squats a little, using that outside rear bumpstop even more. The balance of the car has changed and it starts to drift great! Maybe it doesn’t drift enough, so a longer or stiffer bumpstop could be put in the rear. If it drifts too much, then a shorter or softer one may be required.
shogun32
Northern VA
The car may already be leaning on the outer bumpstops, and applying gas causes weight to transfer to the rear and it squats a little, using that outside rear bumpstop even more.
except these Ford/Steeda bumpstops are nigh rigid. The Eibach's are positively squishy by comparison. If you're on the bump stop, more weight has no place to go but into the tire sidewall. Which to a point may be fine. But if you exceed the tire's carrying capacity you lose traction.
K4fxd
NKY
The bump stop is another tuning tool.
GT 550
Australia
Black GT MT S550
Agree, hence I guess why the article goes on to explain the importance of considering bump stops as an important part of overall susp tuning for the intended purpose. Squishy or rigid doesn't matter as long as it works with everything else noting oems don't always get it right either.
TeeLew
So Cal
Tim
OK, truisms aside, what aspect of the longer bump rubber did you find advantageous?
K4fxd
NKY
It stopped rolling over on the rear tire.
Norm Peterson
corner barstool sitter
Norm
'08 GT #85, '19 WRX
I'm sure that your car's rear bushings are stiffer in some directions than in others. My guess is that they're stiffest in the vertical compression direction, and get progressively stiffer fairly quickly. I'm not sure about how the 'extension side' of these bushings are detailed, but I wouldn't expect that to be a major NVH path.
Norm
compprep
Central, New York
Jim
19 GT PP1, 86 SVO, 24 S5, 74 MGB GT
Chassis stiffness is analogous to improving the foundation on your house. You might not notice it initially, but it will be obvious over time.
This is why I added the 4 pt Steeda K brace. Plan on keeping the car a LONG time. When it's 15-20 yrs old it "should" be a little tighter feeling than one same age/milage/etc. that didn't have a brace. Fingers crossed for next 2 decades!!!
TeeLew
So Cal
Tim
Do you have subframe connectors on your SVO? They were a massive difference on a Fox chassis car.
compprep
Central, New York
Jim
Yes the 4 point that tie's to the seats and welded, not bolted to the sub frame. Car still feels like crap compared to most ANY new car. Big hole for the hatch deosn't help any either. Don't care as, hey, it's an SVO! I've had it since 6/89! Half my life!!!!!!
Norm Peterson
Norm
'08 GT #85, '19 WRX
That's a bushing durability issue rather than a chassis stiffness matter. When you're breaking or tearing the bushings, you're trying to turn the connection from something relatively solid to a hinge with lower stiffness and increasing the amount of relative movement. Eventually the joint comes up solid but you're going to hear and feel it when it does.
I would think that more front bar would make life easier for those rear bushings rather than harder. But if that lets you drive a lot harder, maybe that's the bigger effect . . .
Norm
Andrew@Lethal
West Palm Beach Florida
Andrew
