Changing rim size?
frank_white
NJ - USA
Frank
2021 GT Convertible, Velocity Blue
Hello. I have on order a 2021 Convertible GT Premium with Performance Package and some other stuff. Since I'm in the north east, I can't run the summer tires year round. I think the easiest and most cost effective solution is to get a second set of tires/rims.
1. Do I have to stick with the 19/19.5 setup or can I go down to an 18 or smaller?
2. Should I keep it staggered?
3. Open to decent but cheap rims and tires for the winter (would like a Cobra R look, in black)
TIA
shogun32
Northern VA
you can run whatever fits. SOME 18's clear the front Brembo. Get with DiscountTire or a friendly supplier if you want to try some 18's that are not yet known to fit. You can put 17 on the rear.
hell no
get with @bjf102 he wants to dump some 20x8.5s
bjf102
Glassboro, NJ
Benjamin
2017 Mustang GT Premium
hell no
TIA
Where in the north east are you? I'm in Jersey, but looking to upgrade my wheels atm. Currently I have a set of Rovos Pretorias in gloss black size 20x8.5.
MidwayJ
Dallas, Texas
Jay
2019 Mustang GT Coupe
Used stock takeoffs are good for winter wheels. However, my understanding is none of the stock 18x8 base wheels on non performance pack cars clear the Brembos. Some of the 19x8.5 stock wheels (maybe all of them?) do clear the Brembos. The blackout package wheels and the Ecoboost performance pack wheels definitely fit.
Dana Pants
Burlington MA
Dana
2018 GT PP1
I have 18 inch summer wheels (Enkei PF01) and recommend strongly against 18 inch winter wheels because the caliper to wheel clearance is ~0 and any sand or rocks get stuck and start scratching up the inside of the wheel. If you do that long enough, you will have a part failure. Anything 19x8.5 or 19x9 is a good option. Keep all 4 wheels and tires the same so you can rotate.
Grintch
Hunstville
2015 GT PP
Right, some 18" wheels will fit with the Brembo's but clearance will be minimal (snow & gunk likes to build up in odd places sometimes) and they are usually more expensive than 19" options.
I would use the heavy OE wheels for winter use and get something lighter and wider for summer/performance use. If you need to swap the stock tires over, the 255 fronts will still fit a 19x10" wheel.
frank_white
frank_white
NJ - USA
Frank
Central NJ. I'll keep that in mind, but I'm definitely waiting until I get confirmation that this car is actually coming before I pull the trigger on anything.
