Yeah I was the same I just read a lot of good stuff about redline and amsoil but redline for me seems to be more readily available so I went with them and I'm glad I did. Trans is a lot quieter. It even says it on their bottle. Im excited to see what their engine oils offer.There's so many schools of thought on which transmission fluid to use. Trying to get my head around which is the best compromise. Really want smoother shifting but more importantly want to avoid any extra NVH, which I've read is sometimes a symptom of the common trans oil swaps
Accord to redline it's not in their recommendation anymore apparently the mt82 has different recommendations. Wether it voids warranty is up to Ford, regardless though if anything does happen in order for Ford to deny your claim on it they would have to prove that the fluid was the root cause of failure. Which I've never ever seen that happen.Yikes. Good to know. So I'm assuming the Red Line does not void the warranty then?
They also have to prove though that it did though. They can't go off assumption. Because you can hire a transmission specialist and he can say the same thing. In court it's about proof. You can take it to a small claims court let them know that there's no actual proof that the oil damaged the transmission. Ford has to honor warranty if they want to deny the claim they have to prove that the oil caused the damage. It's about what you can prove in court and hopefully that still stands lol.I think in practice (regardless of the spirit of the law), the dealer is likely to deny a warranty claim - which may or may not be the same as voiding the warranty - based on a modification or change of parts/lube. It then falls on the customer to prove that the modification didn't contribute to the failure, which would be hard to do without any test data - and the oil manufacturer openly acknowledging that they don't meet Ford spec. I don't think that is really how the Magnuson Moss Act is intended to work, but that's how it often seems to go down in the real world.
Basically, don't expect that the dealer would have to prove your change caused the failure. They'll make the assumption it did first thing if they can. You'll have to prove it didn't, assuming if it becomes an issue.
