Cat delete Question
VooDooDaddy
SW Iowa
2016 GT Premium
Yes, that is what I have on my 2016 GT.
However, I used the Borla/FP resonator to replace an SR Performance X-pipe (below) that had previously put on the car that replaced the factory "suitcase" resonator.
https://www.americanmuscle.com/sr-performance-xpipe-1516gt.html?utm_content=Exhaust - Midpipe|SR Performance&T5_Var4=388985&utm_source=google-pla&utm_medium=shopping&T5_Var2=shopping&utm_campaign=AMM+Mustang+Vehicle+Medium&T5_Var3=blue&intl=0&dialogtech=ppc&gclid=EAIaIQobChMIqdCHxKLO5AIVAh-tBh2ZJgiiEAQYASABEgLNC_D_BwE&gclsrc=aw.ds
I had to get rid of the x-pipe because, when combined with the Roush A/B's and the cat-delete's (as previously mentioned) the volume and RASP were simply reedonkulas!
The SR Performance x-pipe was physically longer than the Borla/FP resonator, which means the FP resonator couldn't be directly fit in place of the x-pipe.
What I ultimately had to do (and it worked quite well) is to cut some length of tubing off the x-pipe, and clamp it to the end of the resonator to make it exactly the same length the x-pipe had been. I then clamped that combination to the rest of the factory exhaust system backward. And here is what I used to do it.
https://www.amazon.com/Evilenergy-Joint-Stainless-Exhaust-Sleeve/dp/B076J5HSNJ/ref=sr_1_2_sspa?crid=FDWRY4ZJIO7O&keywords=exhaust+clamps+2.5+inch&qid=1568393799&s=automotive&sprefix=exhaust+clamp,automotive,160&sr=1-2-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFYS0NEMzNaQzI4Vk8mZW5jcnlwdGVkSWQ9QTA2NTYxMjYxRjc3N0pKMTlQTFExJmVuY3J5cHRlZEFkSWQ9QTA5MDg2NzZaWTFLSTNFRjRPNkkmd2lkZ2V0TmFtZT1zcF9hdGYmYWN0aW9uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
I have driven my car about 3,000 mile since making this frankenstein system work, and I was under the car recently to make sure everything was secured well, and it still is. Nothing has moved at all.
Granted, if you still have the factory "suitcase" resonator on your car, then the Borla/FP resonator should fit, no problemo.
To anyone who has deleted their cats, has an x/h-pipe and a loud axle-back exhaust system; and the rasp/volume is a bit too much, if not ear splitting/embarrassing; I can't recommend the Borla/FP resonator high enough. Although it may not be inexpensive, it is easy to install with a set of jack and jack-stands, a socket set, and a saw-zall; but more importantly it will transform a car that is obnoxious to drive into the car you look forward to driving again!
BlueCollarDaily
Shawn
2019 Mustang GT 400a
I use them and yes they work. The ones from bigdaddiesgarage are the best.
I messaged them which one of the 3 they recommend ( cause I didnr know if I needed the 90 degree ) and they said they didnt have a product for my app?
Can you link me to the ones you used?
Thanks a lot!!!
sloride
ohio
2016 GT
Anyone have the part numbers used for the 2.5” and 3” magnaflo tru x resonators. Thanks!
TheHydro
Las Vegas
2015 GT Performance Pack
Tycoon
PA
2018 Mustang GT Premium
I have a Kooks catback for a 2018 GT. I will use the factory manifolds, so I'm not using the Kooks H-pipe. Should I go with the factory resonator or the the FP/Borla M5231M8 or something else? I'm hoping I can get a really deep sound with literally no rasp.
FP resonator:
https://accessories.ford.com/2015-2...777986!!20643481100!157311292289&gad_source=1
Kooks catback:
https://kooksheaders.com/exhaust/ca...tips-2018-2020-mustang-gt-50l-connects-to-oem
