Car running 67 maf flow rate lb per min
kufty
Arizona
Aldo
2014 Mustang GT
I’m not a mechanic or know much especially about tuning and datalogging but i’ve been having issues with my car, i’m on a cobra jet setup w a 65mm twinjet tb, long tubes no cats on a gen 1. Datalogging shows about 67 maf flow rate lb per min at around 7800rpm. I’ve already tried a new DW400 fuel pump twice but it didn’t solve the issue so I wanna know what I should look out for or what else can be causing that, If appreciate the help thanks!
engineermike
La
2018 GTPP A10
67 lb/min sounds high for an na car. Are the fuel trims way negative? Could be a bad maf transfer function.
kufty
Arizona
Aldo
2014 Mustang GT
If you’re referring to lambda, car hits .90 at 7800 which is also bad, but i can’t figure out the issue and it’s remote tuned so I cant really take it in to my tuner
SheepDog
Colorado
Dax
Not unless you're making 600+ HP.
Has it always been this way, or did the logs recently change?
What are your fuel trims at Idle and cruise, not just WOT
Who tuned your car? Could just be that the MAF Scaling is wrong, for whatever diameter your intake/MAF housing is.
engineermike
La
2018 GTPP A10
Either it’s making some serious na power or the maf curve is bad along with the injector data (assuming he’s looking at fuel trims correctly).
kufty
Arizona
Aldo
2014 Mustang GT
It’s been like this since I put on the cobra jet setup, before that car was stock no tune, when i’m cruising at like 60mph 2500rpm the fuel trims are 1.0-1.10, i don’t have any recent idle logs, this is all on e85
kufty
Arizona
Aldo
2014 Mustang GT
I don’t know if it’s making all the power it should, my 60-130 is around 9.4 seconds (i don’t know if that’s good or bad for the setup i have)
kufty
Arizona
Aldo
2014 Mustang GT
Sorry i forgot to say but it’s tuned by Tricky
Pistol_91
Clearwater
2020 mustang GT
I don't understand what the problem is here you're trying to fix.
kufty
Arizona
Aldo
2014 Mustang GT
I just checked for codes, p0507 popped up because the car was idling weird jumping to 1k, is this a separate issue or can it be connected to the car running with too much air?
tdstuart
Arizona
Triston
2015 Mustang Gt Premium
I have seen this issue with a tuner I used where the car looked like it was using enough air and fuel to make 900hp but I am n/a.
If the injector data and airflow data are both off it could produce the results you are seeing.
I am not sure if the tuner I was using was messing with injector data. I don't see why he would, I think there was another set of parameters he was changing as he was having an issue tuning the car due to the cams. I would have to pull his tune to know for sure. I feel like he was doing something with the torque calculations but I remember it resulted in a really high injector usage and duty cycle that wasn't real.
Tricky should have the right injector data for your injectors so if the fuel trims look good your airflow should be right, but 67lbs is not right unless you are max max effort an.
What injectors do you have?
markmurfie
Hawaii
Mark
2015 Ford Mustang GT
Flex fuel tune?
The adaptive stoich logic can trip up even the best tuners, espeaclialy if they are remote and are not thinking about what E% the car actually has in the fuel tank.
