Can't Connect FordPass
akoster
Atlanta, GA
Andrew
2020 Mustang GT Premium w/ Performance Pack
I have been trying to connect my 2020 Mustang GT Connected to FordPass on my phone, but the prompt is not showing up on my screen.
I have made sure Sync is updated to its latest verison and also done a Master Reset. That not helped.
Anybody have any recommendations on what else to do?
Paddles
TX
Richie
2023 Mustang GT
Well since you asked for other recommendations... I recommend removing the telematics fuse from the car and uninstalling the pass app so Ford can no longer collect your data.
But I know that's not for everyone.
Have you already installed the app on your phone and created an account and added your vehicle to that account? Now you're trying to activate from the vehicle side but not seeing the prompt on your in-car display?
Do you have the vehicle connectivity settings and location sharing settings enabled? If they are disabled the app won't find the car.
The Demon
Brett
2022 Mach 1 N5809
I said the same thing @Paddles does. My 2019 couldn’t connect either and it was the best thing that ever happened to me. The dealer was so pissed that they couldn’t get it to connect and I laughed.
akoster
akoster
Atlanta, GA
Andrew
It won’t let me access the Connectivity Settings. This is what pops up when I try to do that.
Johnny Rockit
Massachusetts
Johnny
2022 Mustang GT 6-speed. 2015 F-250XLT,73 Torino
It took me an hour to read the new user agreement to get in the app again. I may be pulling that fuse myself soon.
Paddles
TX
Richie
2023 Mustang GT
If restarts and master resets haven't worked then it could be a hardware problem. Maybe the fuse is burnt or has already been pulled?
Skye
ā‰ˆ39N
"Skye" Mach1 N2144
New (to the OP) car, with connectivity issues. I'm going to attach a few links of things to check.
The first two cover a topic that is becoming more and more common in the industry: GPS vehicle trackers. Many people, especially when buying a used car, later discover :curse::angry:a tracker. These are installed to recover the car in-case of theft. Or from a driver delinquent in payments. The nature of these devices on the car's internal network is enough to interfere :crazy:with systems or features.
https://www.mustang6g.com/forums/threads/unidentified-module-added-to-car.202674/
https://www.mustang7g.com/forums/threads/hidden-tracking-device-plugged-into-obd2-port.162356/
There's no one common device. But they're connected in the vicinity of the On Board Diagnostics (OBD) port, inserted in-line or attached with vampire taps. I've included a pic of the car's network. On the back end of the OBD port is the hub/switch for the Controller Area Network (CAN) bus: the Gateway Module.
https://www.mustang6g.com/forums/threads/s550-electronic-modules-and-their-networks-a-primer.195769/
The next thread covers the topic of Ford's Telematics system; it describes how to disable the service. Some opt to remove the fuse. Others, separate the antenna connections in the trunk.
https://www.mustang6g.com/forums/threads/the-how-to-disable-the-data-link-to-ford-thread.146863/
Sync is now a legacy system. I think the last update, a maintenance update, was in 2024. If the OP chooses to disable connectivity, it can easily be regained for map or service updates.
https://www.mustang6g.com/forums/threads/official-ford-sync3-3-4-release.145436/
If the OP continues to be interested in adding the car to the Pass App, one thing that might facilitate that is a Ford Customer account (if not already created). It can be established, here.
https://login.ford.com/4566605f-43a7-400a-946e-89cc9fdb0bd7/B2C_1A_SignInSignUp_en-US/oauth2/v2.0/authorize?redirect_uri=https://www.ford.com/support/&response_type=code&state={"policy":"email_susi_policy","lang":"en_us","state":"L3ZlaGljbGUtZGFzaGJvYXJk","queryHash":"","forwardUrl":""}&client_id=77d5d23f-7d9a-4850-aaee-ddb496bb27dd&scope=77d5d23f-7d9a-4850-aaee-ddb496bb27dd openid&code_challenge=fbv9LuCB9c3eWPwaHpX9JuQrqPTxIijwvK-6IM52LZo&code_challenge_method=S256&ui_locales=en-US&template_id=Ford-MFA-Authentication&ford_application_id=4f5eebbd-97ba-4ca6-a2d3-1d2d7bfe5a1a&country_code=USA&language_code=en-US&bypass=signup
But ya: fix vehicle connectivity first, then delve into Pass App.
If a tracker is found, be sure to do a drive-by and chuck it at the dealer. :bandit:
Edit,
If a tracker is found, but it's installed in such a way removing it is a question mark :question:, return to dealer and wait until it is removed. Afterwards, while still there, inspect the area to ensure the car is tracker-free and there's no damage. Connectivity could be fixed just by doing that.
Good Luck OP. :please:
Edit (again) :giggle:,
Being an electronics issue, there could be several things. Spitballing...
- Check for a tracker. Locate the OBD port and just give things a good visual
- Check the fuse panel supporting the Body Control Module (right, floor, behind passenger kick panel)
- Factory default the Sync system. This will remove any previous settings
https://www.ford.com/support/how-to.../how-do-i-perform-a-sync-masterfactory-reset/
- If you have an OBD scan tool, check for any codes. I understand there's currently no wrench light
- Disconnect the battery, let the car sit overnight, then reconnect
Any of those checks or tests could give you tells as to what the problem is. If those, Member posts here and your own thoughts don't clarify what the problem could be, check back with the dealer and discuss.
If you have time, let us know what comes about. :like:
