Blk2015GT
So an owner should never have to lug nut torque and when the rim breaks Ford must eat the cost? :shrug: Things happen, parts wear and come loose/break. You are correct, one SHOULD not have to check but is a few minutes of time monthly as insurance not worth the benefit of it not vibrating loose versus months while Ford replaces the engine under warranty? I check my GT every so often too; it literally cannot hurt anything and takes all of 2 minutes to check the ft lbs. The flip side is MUCH worse.Quite easy really if you look at all the facts; we've been given a wrench to "check" or retighten the filter as required. An owner should Never have to be checking their oil filter out of fear that it may come loose and destroy their engine...
If the canister was not a superior design, then you would also see a specific wrench given to future owners for them to "check" theirs as well. Dealership mishaps with regards to not torquing down the filters are definitely an issue, but seeing as there is no specific wrench or notice accompanying the updated cars telling owners to check their filters, then logic says it must not be necessary with the new design.
I can point you to dozens of instances on the internet of varying cars the filters fell off damaging the car. Simply google "oil filter fell off." Miatas, corvettes, hondas, Nissans, Toyotas, on and on. It simply happens and it's not set it and forget it despite common belief; just like you should check your lug torque every month or two for piece of mind. A few minutes saves expensive damage.
As I said, Im sure it's for users to do their own changes at home to ensure it's on there tight enough; and if needed to retighten properly. NVH is a known issue with these FPC engines, there is no way around that.
I never said the canister was not a better design in terms of of staying on the block. Is it "better" (flow etc) no one knows, but I doubt it. It's not some conspiracy to give new owners a better flowing filter. it may simply be cost benefit that they've replaced x engines at a high cost due to filter issues, and used statistics to determine future failures, and changing the design was cheaper. It may as simple as the canister design is a more "fool proof" design or has some extra mechanism that it cannot vibrate and turn off.
