swoop1156
Surely. I suppose you could get in-depth and see if something such as this exists for Mach 1 as well, or even try this method and see what happens...?You can also reset the KAM via Forscan, I've done it via Battery disconnect and Forscan, I couldn't tell the difference between each type of reset, you would think the Forscan reset would be more thorough.
After a reset, the car shifts a little odd for the first 30 mins to an hour then seems to settle down to normal shifting after that. This is all just based on my experience so far.
Hope you have a long long stretch of road!1. Using the scan tool, clear the DTCs (Diagnostic Trouble Codes) and Transmission Adaptive Tables.
2. Drive the vehicle until the engine and transmission reach normal operating temperature.
3. Accelerate from a stop with light throttle (15%) ensuring that upshifts 1st through 8th occur at engine speeds between 1300-1600 rpm.
4. Continue to accelerate (may apply slightly more throttle after 7-8 upshift at 32-38 mph (51- 61 km/h) until you achieve 55 mph (88 km/h) and the 8-9 and 9-10 shifts complete.
5. Brake very gently to a complete stop and hold foot on brake for five (5) seconds.
6. Shift the transmission to Neutral. Wait 1 second.
7. Shift the transmission to Reverse. Wait 2 seconds.
8. Shift the transmission to Neutral. Wait 1 second.
9. Shift the transmission to Drive. Wait 2 seconds.
10. Repeat Steps 3 through 9 six additional times.
© Copyright 2020, Ford Motor Company.
