Can I swap out axleback system?
rollingshi59
Duluth GA 30096
2020 Mustang GT Base A10
Currently running lth catback system for 18-20 gt. Can I swap out lth muffler and swap to flowmaster axleback system? Wondering if there will be fitment issues.
m3incorp
Georgia/Colorado
James
Where there is a will, there is a way. It is called cut and weld; exhaust shops can make almost anything work.
MidwayJ
Dallas, Texas
Jay
2019 Mustang GT Coupe
If the lth system is the same pipe diameter as stock, then the new axle back should cut and clamp in just as it would to a stock system. If not it should still be easy for a muffler shop to weld it in.
AZ18yote
Arizona
Bryan
Depending on the flow master setup you are looking at beware of drone though.
Stephen@lethal
2020 Mustang Gt500
To be honest, there isn't going to be a big difference in price between most catback systems and axle back systems. I would just swap the catbacks to play it safe. Hit me up if you want to check out some pricing on some setups. Lethalperformance.com
IrishStallion
Missouri
18 gt mustang
I run the American Thunder system with stock resonator. It would be crazy loud with cat delete and or resonator delete. For just an axle (resonator) back it sounds really good to me.
rollingshi59
Duluth GA 30096
Decided to get another set of catback exhaust and I'm debating between roush catback or awe touring. Any suggestions?
AZ18yote
Arizona
Bryan
Both sound great. Both can be loud. Low RPMs AWE volume can be controlled. If ever going long tubes definitely recommended AWE over the Roush. I had Corsa Xtreme connected to ARH headers but eventually cut off the Corsa mufflers and added AWE touring mufflers to the Corsa double X and was my favorite combo so far in term of sound. The AWE full cat back with their H pipe and resonators has a tad lower sound but still screams up top. Roush is probably a bit louder over all.
rollingshi59
Duluth GA 30096
I have Roush blower and is it necessary to get 3in diameter exhaust system? I am not sure what size Roush Catback has
AZ18yote
Arizona
Bryan
On a fi setup full 3" is beneficial.
