Camber adjustment
JohnBoyNC
Indian Trail, NC
2015 GT PP
I just had the alignment done after installing the Eibach Pro-kit and here are the end results:
Front
Left camber -1.8
Right camber -1.7
Left toe -0.01
Right toe -0.01
Rear
Left camber -2.2
Right camber -1.9
Left toe 0.1
Right toe 0.1
Not a DD nor a track car, but I do enjoying spirited driving and would like to get decent mileage from the stock Pirelli's.
What are your recommendations? Leave it alone? Camber bolts? Adjust the front and or rear to what?
TIA for your suggestions.
Niz55
Us
17 GT350
Your rear camber is adjustable. I have the same springs and my front camber is -1.7 on both side. Loosen the 3 nuts on the strut tower and pull the strut assembly towards you. This will give you +0.2 camber.
If you decide to get bolts go with with eibach recommendation. I belive it is -1.2 front and -1.6 for the rear
JohnBoyNC
JohnBoyNC
Indian Trail, NC
2015 GT PP
So what should the rear camber numbers be more like?
Niz55
Us
17 GT350
-1.6
Just go with eibach recommendation..
Front Specs
OE rate: 28 N/mm (160 lbs/in)
SPORTLINE progressive rate: 38 - 58 N/mm (217 - 331 lbs/in)
Bump-stop: New Eibach bump-stop
Damper: OE
Tubing: Yes
OE wheel center to fender: 396 mm (15.6 in)
SPORTLINE wheel center to fender: 357 mm (14.1 in)
SPORTLINE can be aligned to OE Specs: Yes
Front Alignment:
OE Camber = -0.8 deg (+/-0.8 deg)
OE Caster = 7.2 deg (+/-0.8 deg)
OE Toe = 0.00 deg (+/-0.2 deg)
SPORTLINE Camber = -1.2 deg
SPORTLINE Caster = 7.5 deg
SPORTLINE Toe = 0.2 deg
Rear Specs
OE rate: 117 N/mm (668 lbs/in)
SPORTLINE progressive rate: 154 - 174 N/mm (879 - 994 lbs/in)
Damper: OE
Tubing: Yes
OE wheel center to fender: 387 mm (15.2 in)
SPORTLINE wheel center to fender: 353 mm (13.9 in)
SPORTLINE can be aligned to OE specs: Yes
Rear Alignment:
OE Camber = -1.2 (+/-0.8 deg)
OE Toe = 0.1 deg. (+/-0.2 deg)
SPORTLINE Camber = -1.6 deg
JohnBoyNC
JohnBoyNC
Indian Trail, NC
2015 GT PP
I appreciate your response and pointing me in the right direction. Looks like those are the recommendations for the sportlines ok, while I have the pro-kit, but I was able to find the ones I need.
On my spec sheet from the place that did my alignment has the toe specs for each side and then they also give you a total toe (the two added together). Question: the toe specs in the Eibach recommendations above, are they per side or total?
Just a newb trying to figure this all out.
Thanks
Niz55
Us
17 GT350
It is per side. your first post you mentioned that you have eibach sports.
JohnBoyNC
JohnBoyNC
Indian Trail, NC
2015 GT PP
ArrestmeRed
LI, NY
2016 mustang
Stock Pirelli's don't last for anything. The backs will be toast by like 15k from what ive read. I've switched to continental DWS all seasons and I barely am going to get 10k out of the rear tires. Might have something to do with racing it but I run similar rear camber adjustments.
phil545
Australia
Phil
Hey guys
can you tell me how the rear is camber adjustable? My wheelie guy couldn't work it out so in negative 2 degrees at the moment
Thanks!
BMR Tech
Tampa, FL
www.bmrsuspension.com
Dion
Upper camber link, inner mount to cradle.
Loosen bolt, adjust, tighten.
Niz55
Us
17 GT350
You can also slot the top strut mount holes to get your camber within spec. Free
