Camber Adjustment
Myshelby3425
Miami
2018 GT
I lowered my 2018 GT on BMR Minimal drop springs and FP track shocks. The car has a good amount of negative camber in the front and rear after lowering. Is there anyway to correct the camber in front and rear without adding camber kits? If so, how much adjustment can be made?
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
In the rear, yes. It's adjustable. Front, no. What does your alignment sheet look like? Based on the drops of the springs you bought, you're very likely in a good place for both.
Myshelby3425
Miami
2018 GT
I haven’t gone for an alignment yet. Wanted to have everything I needed before taking it for alignment. Drove it a few miles and the contact area of the tires with the road is on the inside tire edge til about 2 inches away from the outside. I have 19x10 275s up front. I purchased a set of camber bolts just in case I needed some minor adjustment
CEHollier
Prairieville, La.
Charles
2015 GT Premium Magnetic
Agree. Mine was very close before alignment. Did you reindex the bushings?
BmacIL
Enginerd
Naperville, IL
You don't want the tire flat to the ground static. When the car rolls, it loses camber and you definitely don't want to go into positive camber. Some negative camber is required to ensure proper contact patch in cornering. -1.5 front and -1.3 rear should be your target for a street driven car.
CEHollier
Prairieville, La.
Charles
What you posted for me. Brian do these specs work on an 18?
Myshelby3425
Miami
2018 GT
Great, thanks for the input guys. Going to schedule my alignment.
BmacIL
Enginerd
Naperville, IL
Darkhelmet22
Fort Worth
2015 Oxford White 5.0
My front camber is -1.5 but rear camber is -1.7. I haven't found the motivation to mess with the rear camber setting lol.
Bluemustang
2015 Mustang Base GT
That is perfectly fine IMO. Not far off from the FRPP track specs which I’ve used on my car. It works and works well. You’ll be just fine.
