Calimer transmission isssues
BlownCoyote
Berkshire County
2016 Coyote Blown
Bought a modded s550 with Calimer tranny and Mantec clutch. If I come to a stop, it’s really weird the car won’t come out of first gear unless I shut it off and turn it back on. And if I let my foot off the brake with the clutch disengaged it wants to creep forward. It doesn’t happen all the time.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Something is binding. Probably a fork.
Austin1992
Indiana
2019 GT PP1
Sounds to me like the hydraulic line has a bubble or something not allowing the clutch to fully disengage
Austin1992
Indiana
2019 GT PP1
BlownCoyote
Berkshire County
2016 Coyote Blown
Never. Only happens when creeping to a stop. I engage the clutch and leave it in first. I guess it’s just my driving habit then I generally throw it in neutral while the car is stationary. For what it’s worth previous owner said the Barton shifter was mounted directly to the transmission.
Rapid Red
Woodstock GA
Greg
Does sound like the clutch could be dragging. Answer Austin's question, or with the gearbox in neutral. Start the car, then try to put it in 1st, my guess will not go in gear easily'
clutch not disengaging completely, gearbox still spinning.
"And if I let my foot off the brake with the clutch disengaged it wants to creep forward." clutch not disengaging completely, gearbox still spinning.
Another suggestion check Mantec clutch website see if there is anything there regarding clutch drag & possible adjustments/ suggestion.
For instance
https://manticclutchusa.com/pages/hydraulic-throwout-bearings-spacers
As you do not know who did the install. That is a hell of a nice part. Quality parts require specific installation procedures.
Shifter gearbox mount has nothing to do with the problem as described.
BlownCoyote
Berkshire County
2016 Coyote Blown
Love this yes clutch certainly feels like dragging. Perfect description thank you
Austin1992
Indiana
2019 GT PP1
Weird that the clutch is grabbing enough to inch you forward but it’s not hard for you to put it in gear. Does it grab really low in the pedal travel? I’d make sure the fluid is topped off, bleed it, and go from there.
BlownCoyote
Berkshire County
2016 Coyote Blown
And yes gearbox is clunky at best. Lots of noise from Calimer upgrades which I love the noise. But certainly thuds and clunks when going into gear. But smooth at WOT
BlownCoyote
Berkshire County
2016 Coyote Blown
The pedal travel is great. But clutch definitely drags intermittently. Also failed to mention prev owner built it let it sit for a year before I bought her. Ive put maybe 200 miles on her since I rook delivery
Rapid Red
Woodstock GA
Greg
Yes, the sound is a clunky BEAST. Don't know the gearbox, but square cut gears do make music, thrash.... :thumbsup:
