Bump stops
saltydogg
NC
2018 GT Premium convertible - 401A, 6MT
So next weekend I'm going to install a set of Steeda pro-action struts/shocks (non-adjustable) and BMR SP763 springs. My car is strictly a daily driver, no track/drag use.
I was going to purchase the Steeda polyurethane bump stops rather than trimming the factory ones but then I read one of the few reviews I could find (on American Muscle's site) and the reviewer thought they were too hard.
What's the general consensus about trimming the factory stops vs. replacing with something after-market? What other aftermarket options are out there?
Thanks!
RonStang6G
Nevada City, Ca
Ron
2016 Mustang GT Premium Oxford White Auto
You will get better ride quality with the Steeda bump stops. It is true that they are a harder material but because they are the correct length you will hardly ever actually hit them. I have changed out my springs several times trying different bump stops each time. I thought that the Ford Performance bump stops would give a better ride quality because they are softer than than the stock bump stops but they did not improve the ride quality. The last time I change the springs I tried the Steeda bump stops and the gave the best ride quality by far over the stock & the Ford Performance bump stops.
saltydogg
saltydogg
NC
For the Steeda bump stops, did you use both pieces front and rear or just the base? From what I can tell with the SP763 kit I should use both (or the tall) configuration.
Nagare
Ft Lauderdale
2017 Lightning Blue V6
For just about everything that is not stock height, the short stack is preferred.
I know Kelly recommends cutting the stock ones, so I'd say go with the short stack here too.
whalesalad
Costa Mesa, CA
2016 GT PP
Reviewer thought bump stops were too hard?
Bump stops are not intended to be hit. They are a last resort piece designed to protect the shock from bottoming out completely.
There should be no consideration for comfort whatsoever when deciding on your bump stop. It is not a part designed to influence comfort. It's designed to protect your equipment when it's compressed to its' limit.
Steeda bump stops are great. I have them. I cut my OEM ones the first time I did suspension work and that works fine as well... but the Steeda parts will surely last longer. Regular foam bump stops are known to degrade over time.
Nagare
Ft Lauderdale
I've seen a lot of mention of Eibach including the bumpstops in their rate estimates so I wouldn't say that it is always the case for not intended to be hit. I don't know if it is mentioned in their documentation or not, but I do know that I was riding on the ones they included with the Sportline springs.
whalesalad
Costa Mesa, CA
2016 GT PP
Riding *on* the bump stops? That implies the damper is completely compressed all of the time. It doesn't makes sense.
Nagare
Ft Lauderdale
Not completely compressed *all* the time but the springs are short and the bumpstop isn't significantly different than stock and there was a lot of wear on them in the two weeks or so I had them on before visiting Steeda.
Product listing for them even includes:
Spring rates for the S550 Mustang Ecoboost/V6 Sportline kit are measured as a system, including 10mm of bump-stop deflection. That added bumpstop rate contributes to the final rate of the system, the higher number listed below:
