Bullitt Wheel Specs?
Status
Not open for further replies.
Guy@NemesisUK
Bromsgrove, Worcestershire
nemesisuk.com
Guy
Project NemStang / Modified UK S550 Mustang GT
Does anyone have information to hand on the New Bullitt Wheel Specs?
Specifically Widths & Offsets Front & Rear?
Cheers
rcl4668
Pacific NW
2019 Bullitt Mustang - Dark Highland Green
Cheers
Guy -- I've been curious about the rims too. Here is what i have been able to cobble together from Ford's websites and my local Les Schwab, a tire (sorry tyre) dealer in my area of the States:
Stock rim specs: (front) 19 x 9’’, weight __ lb, 50 mm offset, 5 x 45 bolt/lug pattern, (rear) 19 x 9.5, __ lb, 34 mm offset, 5 x 45 bolt/lug pattern, 72.6 hub bore
Weight of OEM Michelin Pilot Sport 4S tires: Rear 275/40/19 – 31 lbs. Front 255/40/19 – 28 lbs.
If you ever find out the weight of the stock rims (without the tires) let me know.
/Rich
Ericc B
NL/SP
Various Mustang GTs
Aren't they just exactly like the PP1 wheels? 9J19 ET45 front, 9.5J19 ET52.5 rear.
69mach1-395
central nm, usa
2016 RR GT/CS
Should be stamped on the inside of the rims...
Guy@NemesisUK
Guy@NemesisUK
nemesisuk.com
Guy
That's what I was thinking, but being a different wheel design I wanted to be sure. With any one who can confirm this?
rcl4668
Pacific NW
If someone can confirm either way I would also love to know.
slowhand99
Surrey, England
Ben
Mustang GT Vert Race Red ord 26/03/15 del 24/03/16
For some reason all the stock rims seem to be 45 front and 52.5 rear offset but the Bullitt rims are 45 offset front and rear. Is there something different about a Bullitt rear hub?
revinto7
NY
07 shelby-gt 14 camaro SS 1LE
will pp1 wheels fit bullitt like they do on a regular 18-19 GT
Guy@NemesisUK
Guy@NemesisUK
nemesisuk.com
Guy
Thanks for the info! I would have thought they would have been the same as the GT offsets. Interesting to know the hub differences. We had a customer that wanted to look at fitting spacers. But needed to confirm if they were the same as the GT.
Stangnut
S.E. Alabama
Jason
2019 Bullitt BHG
I'd like to know this too, if anyone's confirmed the different offsets.
Schwerin
Home
2019 Mustang
Yes they do. Also Ecoboost Preformance pack wheels fit the Bullitt. They all have the same brakes.
Status
