Bridgestone RE-71R vs MPSS
Apex Wheels
Gold Sponsor
Bay Area
Mustang
Do you know what size squared will work up front? I don't want to rub on the shock tower, I'm on Eibach pro springs if that helps. You run 275's?
If you are still trying to decide, or for those viewing this in the future, we have many customers running 18x11" or 19x11" wheels up front with anywhere from 275-315 tires on them. The key is in the offset combined with a spacer and extended wheel studs which also allows you to easily rotate them for prolonged tire life. Both of our 11" wide EC-7's feature +52mm offset, and require a 25mm spacer to clear stock suspension WITH camber plates. We highly recommend camber plates to get the most performance out of your wheel/tire setup.
If it's going to see limited track use and mostly street use, 10" wide wheel offers more street friendly tires, especially in 19x10" ET40. Plenty of great 285/35-19 summer tires to chose from like mentioned earlier. I would still recommend camber plates to get the most performance, but spacers are not needed with our 10" set at either end. Bolt on and go!
- Cory
