Brembo Upgrade for Base GT
RT302
RT302
Pelham, AL
Jonathan
2015 convertible automatic GT
My apologies if this has already been answered, but what all would be required if I upgraded the stock GT front brakes to the brembo 6 pistons and wanted to move the 4 piston front brakes to the rear?
RT302
RT302
Pelham, AL
Jonathan
Seems like there would be a way to use the calipers from the front on the rears for people upgrading the fronts to the brembos
Labradog
Santa Barbara, CA
Jeff
2016 Mustang GT Guard Metallic
Don’t believe there is brotha. Besides not having a rear parking brake there’s no performance reason to. Plenty of people track their cars with the stock rear calipers, swapping pads (and rotors) for more performance. Also the 4 pistons base calipers are even heavier than the Brembos. If you want an appearance upgrade on all 4 corners the GT350 kit is the easiesy way to do it.
Chef jpd
Brooklyn, NY
^^ what he said. The caliper mounts from front to rear are incompatible, and you would lose your parking / emergency brake completely.
Labradog
Santa Barbara, CA
Jeff
What are the part numbers for the PP splash shields? There are like 3 different “performance pack” “high performance pack” and “track II package” options
Houston Kid
Houston Kid
Houston, TX
Let me dig around. I took a pic of the part numbers. Let me see if I can find them again.
BlownGP
Houston/Baton Rouge
Steven
Pontiac, Ford, Dodge
Like said, not only would be costly to fab up a bracket you would lose the parking brake.
Then there really is no reason since the front brakes do most of the work.
If you just want the look. Then Shelby it is.
Performance nut
TX
2018 Mustang GT A10
Bump for part numbers and results as I'm about to do the exact same upgrade here soon. Want to make sure I have everything I need before starting.
Houston Kid
Houston Kid
Houston, TX
I did not forget. I cannot find the pic. I will get under the car tomorrow and see if the sticker is still on them. As far as performance. Awesome. Zero issues so far and I have a few thousand miles on this set up.
Houston Kid
Houston Kid
Houston, TX
It’s a Ford factory part. Just get the dust shield for performance pack cars.
Houston Kid
Houston Kid
Houston, TX
Guessing the 4h and 5h are for driver's and passenger side, not necessarily in the order.
