Bouncy Suspension
Little Guy
Houston
Kevin
2019 Mustang GT
I am hoping someone can advise me on my problem. I have a 2019 GT PP1. I have the Roush single adjustable coilovers, steeda rear subframe support braces, and steed vertical links. The car seems a little bouncy to me. Any suggestions on what could be causing this. The coilovers were installed first and the suspension seemed tight. NExt were the vertical links and then the support braces.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Try adjusting the rebound of the shocks down until it stops. If you're already near softest settings, add some more. You'll also do well to replace the rear stock shock mounts with one's that don't have rubber in them. The ride improvement is significant.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Yea just play with your shock adjustment knob. Thats why its there. If it bounces slowly and your shock is set on soft setting, go heavier.
If the bounce is fast and your shock is on a high setting, go softer.
Probably the former tho.
#1Roadking
Loudon N.H.
Joshua
2019 Mustang GT 2019 Ford Raptor 2018 Cadillac Escalade
Did you ever figure out your bounce? You don’t have adjustable rebound or compression on your single adjustable shocks.
Little Guy
Little Guy
Houston
Kevin
2019 Mustang GT
im going to take car back to place that installed the coilovers.
