Bought a 2017 GT
hoss12316
Tennessee
Donnie
2017 Mustang GT
Bought a 2017 GT and oil pump gear said nope. This is a list of parts I’m looking at just going to see what I can build. If you have any experience with the parts listed or know a better way or parts please let me know 😅
Never tore a gen 2 apart so any thing I’ll need that’s good to replace while I’m in there as well?
Engine Components:
1. **AMS Racing 1100 HP Rated Forged Ford 5.0L Coyote Short Block** - $7,000
- **Includes**: Gen II Ford 5.0L Coyote block, Ford Racing Boss 302 4130 steel forged crankshaft (M-6303-M50B), Manley 4340 steel forged H-beam connecting rods with ARP 2000 bolts, Mahle PowerPak Plus pistons, King or Clevite racing main & rod bearings, balanced & assembled in-house at AMS Racing with a spec sheet provided.
- **Link**: [AMS Racing 1100 HP Rated Forged Ford 5.0L Coyote Short Block](https://www.amsracing.net/products/...yote-forged-short-block?variant=8554126868516)
2. **King XP Race Series 5.0L Coyote Main Bearing Set** - Price not listed
- **Includes**: Main bearings for the 5.0L Coyote engine.
- **Link**: [King XP Race Series Main Bearing Set](https://www.modularheadshop.com/i-24698060-king-xp-race-series-5-0l-coyote-main-bearing-set.html)
3. **MHS 5.0L Coyote Block Cylinder Support Kit** - Price not listed
- **Includes**: Components to support the cylinder block of the 5.0L Coyote engine.
- **Link**: MHS
4. **ARP 156-5803 - Ford 5.0L Coyote Main Stud Kit with Side Bolts** - Price not listed
- **Includes**: Main studs and side bolts for the 5.0L Coyote engine.
- **Link**: ARP 156-5803 ARP Main Stud Kits | Summit Racing
### Gasket Sets:
5. **COMETIC GASKETS Ford 5.0L Gen-2 Coyote Modular V8 Top End Gasket Kit - PRO1052T** - $500
- **Includes**: Head gaskets, valve cover gaskets, oil pan gasket/windage tray, 3 piece front cover gasket, front main seal, intake manifold to cylinder head gaskets (qty 8), thermostat gasket, oil pump pick up tube gasket, water pump o-ring.
- **Link**: https://www.lethalperformance.com/c...bK7nuWq6jFxFtbUN1mSQ5auIoJkX2M3saAsHVEALw_wcB
6. **MMR 2011-23 5.0 Gasket Kit for Ford Mustang GT / Boss Coyote** - $420
- **Link**: [MMR Gasket Kit](https://www.modularmotorsportsracing.com/cart/index.php?main_page=product_info&products_id=277)
### Fuel System:
7. **Fore Innovations 2015-2017 Mustang GT L4 Whipple E85 Fuel System** - $3,000
- **Includes**: Fuel pump, fuel lines, fittings, regulator, and all necessary hardware for installation.
- **Link**: Fore Innovations 2015-2017 Mustang GT L4 Whipple E85 Fuel System - Function Factory Performance
8. **Full Race | Injector Dynamics ID1300X Injector** - $1,873
- **Includes**: High-flow injectors (set of 8) designed for high-performance applications.
- **Link**: Full Race | Injector Dynamics ID1300X Injector
### Camshaft System:
1. **Modular Motorsports Racing (MMR) Stage 3 Turbo Cams** - $1,595.99
- **Includes**: Intake and exhaust camshafts specifically designed for boosted applications.
- **Link**: [MMR Stage 3 Turbo Cams](https://www.modularmotorsportsracing.com/cart/index.php?main_page=product_info&products_id=320)
2. **MMR Upgraded Valve Spring & Retainer Kit** - $699.99
- **Includes**: High-pressure valve springs, titanium retainers, and valve locks.
- **Link**: [MMR Upgraded Valve Spring Kit](https://www.modularmotorsportsracing.com/cart/index.php?main_page=product_info&products_id=318)
3. **Comp Cams Short Travel Hydraulic Roller Lifters** - $445.95
- **Includes**: High-performance hydraulic roller lifters (set of 16).
- **Link**: [Comp Cams Lifters](https://www.summitracing.com/parts/cca-15944-16)
4. **MMR Lockout Kit** - $199.99
- **Includes**: Components to lock the Variable Valve Timing (VVT) system.
- **Link**: [MMR Lockout Kit](https://www.modularmotorsportsracing.com/cart/index.php?main_page=product_info&products_id=643)
5. **MMR Secondary Timing Chains** - $279.99
- **Includes**: Secondary timing chains for added durability.
- **Link**: [MMR Secondary Timing Chains](https://www.modularmotorsportsracing.com/cart/index.php?main_page=product_info&products_id=241)
6. **MMR Billet Crankshaft Gear** - $99.99
- **Includes**: Billet crankshaft gear for increased strength and reliability.
- **Link**: [MMR Billet Crankshaft Gear](https://www.modularmotorsportsracing.com/cart/index.php?main_page=product_info&products_id=1135)
7. **MMR Oil Pump Gears** - $349.99
- **Includes**: Oil pump gears to handle the increased power output.
- **Link**: [MMR Oil Pump Gears](https://www.modularmotorsportsracing.com/cart/index.php?main_page=product_info&products_id=269)
### Additional Performance Components:
1. **Mishimoto Baffled Oil Catch Can Kit** - $220
- **Includes**: Baffled oil catch can, mounting bracket, hoses, fittings, and hardware.
- **Link**: [Mishimoto Oil Catch Can Kit](https://www.americanmuscle.com/mishimoto-baffled-oil-catch-can-passenger-side-1517-gt.html)
2. **Mishimoto Mustang Thermostatic Oil Cooler Kit; Silver MMOC-MUS8-15T** - $800
- **Includes**: Oil cooler, thermostatic sandwich plate, stainless steel braided oil lines, fittings, and mounting hardware.
- **Link**: [Mishimoto Oil Cooler Kit](https://www.americanmuscle.com/mishimoto-mustang-thermostatic-oil-cooler-kit-silver-mmoc-mus8-15t.html)
3. **Mishimoto Mustang Radiator Ultimate Bundle MMB-MUS8-002** - $1,900
- **Includes**: Performance aluminum radiator, radiator hoses, and hardware.
- **Link**: [Mishimoto Radiator Bundle](https://www.americanmuscle.com/mishimoto-mustang-radiator-ultimate-bundle-mmb-mus8-002.html)
4. **GM Flex Fuel Sensor Kit** - $700
- **Includes**: Flex fuel sensor, wiring harness, and hardware.
- **Link**: [GM Flex Fuel Sensor Kit](https://www.americanmuscle.com/eflexfuel-mustang-eflexplus-e85-flex-fuel-conversion-kit-sk1100us.html)
5. **SCT Performance Mustang X4/SF4 Power Flash Tuner 7015** - $400
- **Includes**: Power flash tuner, USB cable, and custom tuning software.
- **Link**: [SCT Performance Tuner](https://www.americanmuscle.com/sct-performance-mustang-x4-sf4-power-flash-tuner-7015.html)
6. **McLeod Mustang RXT Twin Disc 1000HP Ceramic Clutch Kit with 8-Bolt Aluminum Flywheel; 23 Spline 6335825M** - $1,300
- **Includes**: Twin disc clutch, 8-bolt aluminum flywheel, pressure plate, and hardware.
- **Link**: [McLeod RXT Clutch Kit](https://www.americanmuscle.com/mcleod-rxt-twin-disc-clutch-kit-6335825m.html)
7. **Brembo Mustang GT Series 6-Piston Front Big Brake Kit with 15-Inch 2-Piece Cross Drilled Rotors; Red Calipers 1N1.9047A2** - $5,000
- **Includes**: 6-piston calipers, 15-inch 2-piece cross drilled rotors, brake pads, stainless steel brake lines, and hardware.
- **Link**: [Brembo Big Brake Kit](https://www.americanmuscle.com/brembo-mustang-gt-series-6-piston-front-big-brake-kit-15-inch-2-piece-cross-drilled-rotors-red-calipers-1n19047a2.html)
8. **The Driveshaft Shop Mustang 3.25-Inch Carbon Fiber One Piece Driveshaft FDSH55-C** - $1,800
- **Includes**: Carbon fiber driveshaft, yokes, and hardware.
- **Link**: [The Driveshaft Shop Carbon Fiber Driveshaft](https://www.americanmuscle.com/the-driveshaft-shop-mustang-325-inch-carbon-fiber-one-piece-driveshaft-fdsh55-c.html)
9. **Eaton Mustang Detroit TrueTrac Super 8.80-Inch Limited Slip Differential; 34-Spline 917A731** - $730
- **Includes**: Differential, hardware.
- **Link**: [Eaton Detroit Truetrac Differential](https://www.americanmuscle.com/eaton-mustang-detroit-trutrac-super-880-inch-limited-slip-differential-34-spline-917a731.html)
Transmission:
T56 XL
Lethal Performance Magnum XL T56 Transmission Swap Kit (2015-2017 Mustang GT)
NGOT8R
Adrian
2019 Bullitt
That sounds like a very solid parts list. Will you be using a 2-step device? If so, I don’t believe the MMR secondary chains are up to the task and aren’t recommended. I think most are running Accufab or Boss secondary chains.
I also see you intend to go with titanium retainers over steel ones. I faced that same dilemma when I bought my Livernois HD valve springs (Gen. 3 heads) and research revealed that although titanium is lighter, steel is going to be more durable.
Will You be keeping the factory cam caps or upgrading to billet ones? If it’s the latter, you’ll need to have the heads line hone bored. I wanted to do this, but their tool is like $1800 if you want to attempt it yourself. I’ve also seen a video where a machinist messed up on the process with MMR cam caps and ruined the heads. For that reason, I’ll be sticking with factory cam caps.
What turbo/supercharger kit will you be running and how much boost/power are you looking to make?
The clutch references a 23 spline, but the T56 XL has options for upgraded 26 spline. Given how robust your combination is going to be, I recommend going with a 26 spline tranny input shaft and clutch for peace of mind.
hoss12316
Tennessee
Donnie
2017 Mustang GT
i will keep the chains in mind thanks for looking out! I will probably keep cam caps and pray. I’m running a gen2r VMP kit. I’m thinking of going to a whipple with more to offer. And the transmission is going to be a future upgrade after the engine is sorted. If the current one grenades then that will be the next step 😂. So that clutch kit is ment to be directly after the engine build.
