Idaho2018GTPremium
The Supra has a BMW engine which almost everyone knows underrates them. The ‘21+ Supra makes 370-385 rear wheel hp. A little behind a 2018+ GT, but the Supra is 500 lbs lighter (~3,350 lbs) for a similar power to weight ratio. Car and driver went 12.1 @ 117 mph in the ‘21 Supra. C&D went 12.1 @ 120 mph in the A10 GT with PP1 package. From a dig they are similar. From a roll the A10 GT will slightly pull away but I’m talking like 1/2 a car. I’ve owned both (currently own a ‘22 Supra 3.0 and ‘21 Camaro ZL1) and the Supra 3.0 and a stock A10 GT pull similarly at WOT. I had an almost FBO A10 GT PP1 so in that state it definitely pulled harder on the top end than my ‘22 Supra. The Supra’s 3rd gear is a big drop off from 2nd, so it loses a little ground to the GT at the 2-3 shift which is why it’s trap speed is a little lower than the GT. However, after that, through 6th gear the gears are closely spaced like the A10 so it accelerates almost at exactly the same rate as the GT.Bair14 What are you talking about? The Z4 & the Supra runs low to mid 12's-they only have 382 hp. Go look up what the 1/4 mile time is on a Gen 3 Coyote with an A10 is. The Supra is lighter than the Z4. Coincidentally over the last year, 3 different Supras have pulled up to me at a light-2 didn't try and the one that did got 5 car lengths for his trouble. Beat a base m3 already too.
I know they are fast M3/M4's around with single turbo conversions running 600+ hp. Haven't met any at a light yet. And I do know what fast cars are. A shop in my complex at work does wraps and he has some rich customers with all types of fast cars.
One that really impressed me is a street driven 1,500 hp R35 Nissan Skyline with drag radials on all 4 corners with beadlocks!
Anyway, it sounds like you think an A10 GT is significantly quicker than a Supra, but they’re not. They accelerate very similarly. If yours is modded and tuned then that would give you an advantage over the Supra.
