Ok, so I am about to install a lockout kit and I already have the Steeda alignment bushings installed. My car was aligned with the Steeda bushings, so I have a few questions...
Can I use the existing Steeda bushings by simply cutting them down to the correct length necessary? I noticed Steeda makes bushings for the lockout kit, but I don't wanna repurchase if I can just cut down the ones I have
The other question I have is, would the Steeda bushings even be necessary? I'd keep the other two in place, but not use the two associated with the lockout "arms". Would this cause any issues? Would I notice a difference?
Any help and/or advice is greatly appreciated!
My main concern is my alignment was done with the bushings installed and don't want any issues to pop up. I know there shouldn't be, just overly cautious.If I recall, Kelly at BMR doesn't think the alignment kit is absolutely necessary with the CB005. I have both ready for install so I'm going with both.
He said do the rears first not the front. :headbonk:So... get fronts in first and tighten, and the rears should just line up.
I'm assuming you do them on a lift with the car flat & level?Although the instructions state to use a jack, I have installed and removed this CB005 Kit probably over 20 times now.
I have never once used a jack. I do the rears first, then the fronts...and simply use a pry bar or extension to shift the cradle around if needed to get the front bolts threaded.
It is very simple, feel free to call me if you are still having issues sir.
lol - actually. Most of the time I back the car up on ramps and crawl under the car and get it done.I'm assuming you do them on a lift with the car flat & level?
I ask because most may be doing them with just the rear end on stands which means the car is tilted ... may have an effect on how the cradle lines up??
