Mustang_Lou
- May 1, 2016
- Toronto, Canada
- 2020 Mustang Bullitt
So on ramps is fine without needing to remove the wheels? Perfect!
No problem boss. I will be here if you need any more helpThanks for the help Kelly!
Yup! :cheers:So on ramps is fine without needing to remove the wheels? Perfect!
I have those same ramps, but I have a PP car. Any issues with the chin spoilers scraping, or the wheel well not having enough room for chocks?No problem boss. I will be here if you need any more help
Yup! :cheers:
Sounds good, I'll be picking up a set of the lockouts soon!The car in my pic is my PP.
Ramps and a small piece of 2x4 wood under the front tires. That's how I roll.
Care to write up a how to? I don't see how you can do this without jacking the car up.Actually, here is the first initial install of the CB005 on my daily beater car. Did it in about 45 mins.
Having just done the install on one of these kits, I would say it is possible...but you get a lot of extra room to work with the rear wheels off - especially on jack stands because you are on your back.Instructions DO say to put car on jack stands and remove wheels so I'm confused ... planning on installing in a month or so ... may just put on stands regardless just in case I need access from the side.
