BMR Vertical Link Install
Seatown Stang
HereWeGo
Seattle, WA
Thomas
2015 Mustang GT Premium
Installed the BMR Vertical links last week and I gotta say it was one of the easiest installs so far! Super easy a straight forward. Seems to have tightened the feel of the rear end. Would recommend this for every S550 owner. As far as wheel hop goes, I would say it has a positive impact on reducing the wheel hop, but I haven't ran a full test yet.
[ame]
BMR Tech
Tampa, FL
www.bmrsuspension.com
Dion
NICE! Thanks for sharing!
Those TCA045 are a dream to install, much easier than the others available.
Thanks for choosing us for our Links, I hop you enjoy them.
Stang Racer
Ohio
Tom
2019 Mustang GT A10 301A
Nice! Thanks for the info, on my Mod list:thumbsup:
valentinoamoro
US
15 TY Mustang GT
Thanks. Does it increase NVH and can it be combined with the CB005?
Jeffy_2010
Missouri
Taylor
2015 gt 6-speed/ performance pack Oxford white
I have both the cb005 installed along with these vertical links. There was hardly any change in NVH if any to be honest. I did just install the bk054 differential lock outs and those added a lot of NVH, compared to what it had before. Not enough to annoy you to death tho
valentinoamoro
US
15 TY Mustang GT
Ok. This gets added to my list. I have a feeling I'm gunna skip the diff kits though. Thanks!
Jeffy_2010
Missouri
Taylor
Welcome, just try to help out as much as I can
RomanB
Casa Grande AZ
My vertical links are coming in on Monday, the cb005 already made a big difference. Going to the strip on the 25th for the real test...
Seatown Stang
Seatown Stang
HereWeGo
Seattle, WA
Thomas
Good luck at the strip! how did the install go?
ForTehNguyen
Houston, Texas
15 GT
these were so easy to install
might want to put in a correction that the top bolt is 76 ft lbs. Both arent 129, only the bottom
RomanB
Casa Grande AZ
Install went great. I threw on some drag radials... With the Lockout kit and links and drag radials I am not getting hop. With street tires I am still getting the SLIGHTEST amount. Going to run the drag radials tomorrow at about 32psi... Yea I know 18psi hooks better but I still want a little spin to save the halfshafts
jabrax
Montgomery County PA
Jeff
2015 ruby red PP GT
Silly question. Two bolts came with the links, do they replace the top or bottom?
rvlyssup
Vag...Gun...Stang-NUT
Palmdale...The High Desert of SoCal.
Rand
Lotsa...
No such thing. :cheers:
The 2 bolts / nuts replace the upper factory hardware. You re-use the lower bolts.
Coaster
RallyNorthAmerica.com
Central Ohio
www.imprtcl.com
Brian
'15 Fastback GT Guard
