Wylie C
I worked for an hour and a half on the drivers side. The OEM links almost fall out with the suspension all the way down. Install the new links with the top bolt snug, not tight. Raise the lower control arm to almost stock position, and in some cases higher. The lower bolt will go right in. This was a nightmare until I figured this out. Nothing tells you to raise the suspension this high, but that is the trick.
