BMR SP080 with Steeda Pro Action (non-adj)
s550v6
Long Island
2015 mustang V6
I think I found the ultimate daily driver combination....
Seriously, though, I just got my 2015 V6 auto back from the shop with this combo installed and all I can say is WOW. Ride is much smoother than stock yet there is much less body roll in corners and very little nose dive as well. Bumps just get soaked right up, too!
The height drop in inches is:
Front Drivers Side - 0.97
Rear Drivers Side - 0.49
Front Passenger Side - 0.98
Rear Passenger Side - 0.49
It looks wicked from all angles but, looking at it straight on from the front, you can really see the height difference. I also added the Ford Performance shorter bumpstops. Still to do is to clock the necessary bushings and get an alignment both in about a week.
I need more seat time as well as time to let the springs settle to get more accurate drop measurements but whatever the numbers say, it looks awesome! I will get pictures up here as soon as I can!
Rambl3r
Southern CA
2016 PP GT
The fronts should drop a little more after settling. :thumbsup:
Chez
PA
2021 GT
Just put this exact combo on my EB. Its like a completely different car.
Rebellion
Houston
2016 Competition Orange GT
Post some pics!
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
[MENTION=27845]Jmart[/MENTION]....
Jmart
South Bay Area
2017 GT PP Premium, Lightning Blue
Great data point for sure!
It would be interesting to add LCA bearings to this setup and see if it creates a "bunny hop" effect in the rear. Then add the upper shock mounts and again compare.
s550v6
s550v6
Long Island
2015 mustang V6
LCA bearings are on the way and i considered the upper shock mounts but they are definitely not cheap and i'm not making enough hp or trq to break the stock mount I don't think so that's saved for later.
s550v6
s550v6
Long Island
2015 mustang V6
Awesome right?! What a great pair these are
s550v6
s550v6
Long Island
2015 mustang V6
BMR Tech
Tampa, FL
www.bmrsuspension.com
Dion
In for pics ;)
Also, the front won't settle much. You're likely going to be right at 1.00"....as you have the V6 model which will not see the full 1.2" front drop. The rear drop you got was dead on where it should be though.
Thanks for sharing and I am anxious to see pics sir.
