BMR lowering springs question
atticuskid35
Austin, TX
Kyle
2020 Mustang GT Premium - PP1, 401a, A10, AE
Looking to install bmr performance lowering springs (w/o magneride) with bmr caster camber plates... Should I also buy bmr rear camber adjustment lockout kit to make the alignment that much closer to ford spec? Thanks!
galaxy
St Louis
'17 GT350
It is my understanding that those rear camber lockouts are just that; they lock you out from any adjustability. That does not mean they are going to lock you into the factory recommended setting. I think they are intended to lock that adjustable spot in place and then use an adjustable arm to fine tune camber better than you can get it with the stock adjustment spot.
To me, these seem like better options for adjusting rear camber, but haven't heard too much about them. haven't heard any negative about them either, and in theory, they should be a nice option if you're not looking to spend the money on new arms and such.
https://www.steeda.com/rear-camber-adjustment-kit.html
