BMR For The Win
Doctor Fishtail
Mexico
Mustang GT
Installed the cradle lockout kit sometime ago. That alone stopped the hop. Now just installed BMRs Vertical links, BMR aluminum diff. inserts along with BMRs sway bar end links. Combined with the Konis and Swift springs this car is where it should have been from the factory. Thanks Mr. BMR for all the help and info. :thumbsup:
Burkey
Australia
The CB005 alone got rid of at least 80% of the hop for me. Couldn't be happier with the result, given the price and ease of fitment. :thumbsup:
16s550
Bay area
2016 GT M6 performance pack, whipple charged
Is the BMR lockout Kit only benefit the wheel hop issue or does it have other benefits with my vertical links lowering springs and pro action shocks I don't have any wheel hop that I could notice. Trying to decide if I should add the BMR lockout kit now that steeda released an alignment kit works with BMRs lockout kit
Agent_S550
Legend in his own mind
South Carolina
2016 Magnetic GT PP
It definitely helps. It also helps aid in aligning and keeping the cradled centered. You really can't go wrong with either the CB005 kit or Steeda's cradle lockout kit.
tj@steeda
Timothy
nicktechla
Los Angeles, CA
www.nicktwaddell.com
Nick
2017 Camaro ZL1 Red Hot
you are running the aluminum differential bushing kit? is it pretty rough on the street? or not bad?
Bluemustang
2015 Mustang Base GT
I think the cradle lockout not only helps wheel hops but improves handling because the cradle cannot move side to side anymore during cornering. I've noticed since I had mine installed the rear is stiffer overall, which can have a negative impact on ride quality in certain situations on the street, like turning into a driveway for example. There's less movement in the rear overall and some of the force will be transmitted into the cabin. That's the only negative I could see, and this is very minor and only under certain conditions.
But IME so far I see as much potential for an increase in handling and cornering as benefits for curing wheel hop.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Overall handling definitely improves with the lockout kit. The car feels much more confidence inspiring to put power down. I actually think it improves overall ride quality because everthing's not flopping around like it used to. Certain bump events are a tad more noticeable, but the overall experience is a more controlled ride, even if you feel more. Going over small driveway curbs are actually less harsh than before because the subframe/cradle isn't also moving around a bunch when going over.
Bluemustang
You might be right. I think it's the "certain bump events" as you describe it is a tad more noticeable.
But stock, there's way too much cradle movement, which I think is the biggest thing in this IRS I had a problem with. It made putting power down unreliable and tight cornering unpredictable and if I can even say, unsafe if you're doing an aggressive maneuver.
The next BMR piece will be the CB006. With all the mods I've done the rear I think the front chassis brace would cap it off, even though I do have the strut tower brace already which helped.
