Pauliejr
- Mar 23, 2018
- Long Island
- 2016 GT PP
Yesterday afternoon I finished the install of the differential lockout out kit.
I would like to share some info as well as questions.
#1 I have to say, even with mechanical background, the instructions provided to me were very broad and incorrect.
There are a few mistakes in the instructions that maybe BMR can chime in on. The image diagrams are numbered and there is some confusion in referencing these pictures. Also the bolt size description in a few places was incorrect, causing me to search for a 21mm bolt which is not a 21mm and took me some time to realize I had located the correct bolt, however the sizing was referenced wrong.
#2 This kit was purchased through American muscle. I have noticed this kit is different than that another kit I have seen that has the relief notches in the bushing but same model. My instructions seem to pair up with that kid. Is there a difference between these 2?
#3 the front bushing install is very very tricky if you are doing a diy install. The video on;one don’t mention they have the exhaust dropped. It takes some time but if you move the cradle and rear bumpkin around you can squeeze the front in place.
I would say going back to do this install a second time I could probably cut my install time in half, however I just wanted to put the info out there that there are a few mistakes, and broad instructions that probably would save people a bunch of headaches ahead of time if they were corrected.
I installed this kit along with Steeda rear shock mounts and the car is much much better.
I do have Koni adjustable all around as well as springs.
I have a PP and YES the rear end does make noise/slight wine with this kit, however it is tolerable and I assume not harmful. I may swap to a different fluid.
