Nanashii
I didn't. Two of CJPP's 2015s.Which cars had the Barton and Blowfish? Did you ever drive mine? Can't remember.
Try out the Barton before buying/installing. For me, the shift throws are way too short. I wouldn't want something like that in a DD. It would work well on a track though. I'll probably be going with the Blowfish bracket and retain the stock shifter. Tired that combo as well and liked it a lot.
Have you tried the 2015 shifter or was this on an 11-14? The 2015 is completely different and if the throw reduction is to much for you, then a simple cartridge swap will change the throw reduction. The spring pressure can be changed as well.
All our dealers sell the 25% reduction. Once the shifter is installed the cartridge can be swapped out in less than 10 minutes and that is all done from inside the car. We have an exchange program set up where you just send us the cartridge and we can send you a 20% or 15% reduction cartridge. If ordered direct from us you have your choice of throw reduction, but our dealers only stock the 25% and we handle all the exchanges because it would just be to many items for everyone to stock.I tried it on a 2015 Ecoboost. Interesting, I knew the spring pressure can be adjusted and was under the impression that the throw length can be adjusted as well, but the guys at CJ PP said the throw length cannot be adjusted. If it can be adjusted, I'd certainly put it back on my radar since that was the only issue I had with the shifter.
We need at least 10 more threads on this topic. The horse is not dead yet.There are threads on Barton with Blowfish bracket.
http://www.mustang6g.com/forums/showthread.php?t=24934
