Biggest twin turbos
Bluelightning
Bluelightning
North of Houston, TX
Lightning Blue 2017 GT350, 2019 F-150 4x4 Ecoboost (Daily)
What are the biggest size twin turbos you guys would recommend ? Originally I was thinking SC . But now I'm thinking 2 big twins . 2017 mustang gt . Goal is to reach 800hp . May eventually go more . What do you think ? Would u go bigger than day hellion 62mm ?
If you only want 800hp, and are driving on the street, go with the 55's, as they will spool faster. They might suffer a bit on the top end, but probably not much at that power level.
Coyotes55086
Coyotes55086
Canada
Anthony
2017 Mustang GT
Thing if I would like to leave it open
Because just in case maybe one day I would like more than 800hp
HELLION TURBO
United States
2015 Mustang GT
How different would a 55 be to a 62 ? I know the 62 would take more to spool , however once spooled would hit harder
Hello. There are a few things to consider. We keep the 62mm units standard because they are a great match to this engine in most cases. We however use the 55mm units on Gt350 cars to help make up spool time to help
create low end torque with the 5.2 (the larger cams and port size makes the Gt350 have less low end and more top end power). If you have a 18+ auto the 10 speed will mate well with the 62 mm turbos, and give a great range of power. Some folks like to option the 55mm units on 15-17 cars with less gears in the transmission, to make power quicker. The 55 Precisions are very powerful if optioned, we went 8's with them years ago, and there are members on here who have gone faster than that.
Bottom line, you will not be disappointed with either :)
Please let us know if we can help.
Team Hellion
Coyotes55086
Coyotes55086
Canada
Anthony
2017 Mustang GT
Team Hellion
Hi guys, great and thanks for the response. I have an auto 2017 mustang gt .I would love to keep the car open incase I ever want to go more than 800hp . However for the moment , 800 would be amazing to reach
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
So you are placing an order today?
HELLION TURBO
United States
2015 Mustang GT
If you opted for 55mm turbos it will easily make that with a 3 inch exhaust and proper fueling. We have made over 1000 with those turbos. The 62mm units can make over 1200 to the tire.
erikkire18
santa barabra,ca
5.0 Hellion TT
I got 62s and i make 800 wheel on 14lbs. the turbos take a bit to spool but once they hit at around 3-4k rpm its a big hit and it keeps pulling up top. The 55s should be great though for your goal and i think with those you get instant torque appose to waiting a bit longer for the 62s to spool. once i build mu block I wanna get to 18-20 lbs on my set up
Coyotes55086
Coyotes55086
Canada
Anthony
2017 Mustang GT
How would the 62mm work with 93 pump gas? Here in canada I'm not sure if u can get e85 . What kind of power do the 62's make on 93 ?
erikkire18
santa barabra,ca
5.0 Hellion TT
on 91 shitty CA gas spraying meth i was at 600 wheel on 8.5 lbs. so 93 maybe 630-650 wheel? and yes your guna need to know how much you wanna spend. Take my advice and buy once appose to opting to a cheaper option. cuz aside the turbos and install you'll need injectors, BAP and other things like that. better tires, tune etc..
Coyotes55086
Coyotes55086
Canada
Anthony
2017 Mustang GT
Well crazy fast is always nice lol
Zinc03svt
usa
stang
Do you have 10k sitting in a bank somewhere that does not need to be used for savings or living expenses....????? Lol.
Plus a back up 6-8k when you blow your motor??
Torinate
Ontario
2016 GT Convertible
Hope the OP factors in the exchange from USD to Can $. No small amount lol.
