Better MPG on Sport Mode?
show7ime
Arizona
2016 Ecoboost Mustang
I have a Ecoboost and driving in normal I get around 18-23 in city. But, when driving in sport I average above 25-28 mpg? How is this possible... :crazy:
steerage250
Perth
Ian
2016 GT Fastback, 1928 Model A Ford
a change in driving behaviour is surely the only answer?
Brometheus
Chino Hills, CA
Frank
2016 Ecoboost Premium PP 6MT
Hmm... I learned how to drive stick in this car in normal setting until I found out there was a sport mode. Been driving in sport since, but I'm averaging 22 mpg :doh:
x_man586
Thank you Diatoms
Marshall Texas
2016 Oxford White Mustang GT m6
I will try it in my GT and see what happens. Any reason to drive my car more.
Furious D
CLT NC
Darrell
2017 Grabber Blue GT w/PP
There's a normal mode? lol
Rickycardo
Bolingbrook, Illinois
2015 GT auto
With an auto mileage will surely suffer. In Sport mode the auto holds the lower gears longer and rev matched downshifts. I drive my GT in Sport constantly and average 14.7 mph all city.
Furious D
CLT NC
Darrell
Yeah, my biggest gripe about driving around in sport mode all the time was that the car can't decide what gear it wants to be in at 45ish
Rickycardo
2015 GT auto
Bingo! here in the burbs the average speed seems to be right about 43 mph. Just enough to go 3-4-3-4-3-4-3-4 all the way to work.
lzaffuto
Atlanta GA
Lucas
2015 V6 Vert
Depending on the traffic pattern I could kinda see why you might get better gas mileage in sport mode... technically if the engine is engine braking the throttle is completely closed and it isn't using any fuel. So if you are in sport mode and you are engine braking more than cruising at or above idle you could technically be using less fuel.
tcman54
Stanghead
Palm Coast, FL
Terry
2016 Ecoboost
In sport mode you should have reduced mpg because the engine is at higher rpm more of the time than in regular mode, only makes sense.
Terry
Lukasha
Austin, TX
Jeff
Blue Dream
I think it's a matter of math.
Car takes engine power and converts it to movement.
Driving style being the same, sport mode gives you more power and uses the fuel more efficiently to get that power.
Result, engine doesn't need to work as hard or use as much gas to create the amount of power to get the same amount of movement.
Now whether that accounts for the extreme difference in MPG you have, I doubt it. But I definitely noticed a 1-3 MPG improvement when I started driving in sport mode instead of normal.
Jeff
tsunami
Minnesota
2015 Premium EcoBoost Convertible
Lower mpg in Sport Mode.
My EB auto drops mpgs significantly if I put it sport mode. Usually at least 10% decrease more commonly 20%.
show7ime
show7ime
Arizona
Jeff
i don't know either. was hoping for some guidance. i guess i can't really complain... but, its really puzzling.
dev1360
STL
DIB 2016 S550
Jeff
The engine doesn't make any more power in sport mode. It only makes the throttle more sensitive, and in the case of the automatic, changes the shift points.
