Best spark plugs for full bolt on
Angelesco0
California
Angel
2020 Ford Mustang gt pp1
Hey guy I have a 2020 Mustang gt full bolt ons just wondering what the best spark plugs are
robvas
MI
2011 GT
What aren't the stock plugs doing for you?
Skye
≈39N
"Skye" Mach1 N2144
Listing your bolt-ons would be helpful. But if none of those vendors list specific requirements, the stock plugs at their recommended gaps should continue to perform well. In this example, changing the plugs will not increase power, improve drivability or reliability.
Sometimes, drivers will replace their existing plugs with another OEM set, just to freshen things up and confirm each cylinder is looking good. If you go this route, buy the replacement plugs from a reputable source: the dealer or major parts vendor. Third-party sellers have been known to pass off counterfeits.
NGOT8R
Adrian
2019 Bullitt
If you're not misfiring or fouling plugs, using different plugs won't make any more power or anything
My 2019 is an FBO + nitrous car and I have NGK 6510 plugs. It still performs very well (even when not using nitrous). I’m gapped at 0.28 too.
John S
Novi, Michigan
2022 Mach 1 HP
Just curious if stock plugs are preferred if I switch to E85 on a stock engine with the usual bolt-on induction/exhaust upgrades? There's so much conflicting information regarding best heat range and gap for the cooler running E85 fuel I don't know what to think? (I won't be advancing to forced induction so at least that can of worms is avoided. )
NGOT8R
Adrian
2019 Bullitt
You don’t have to go with colder plugs, but it certainly won’t hurt you to run them either. E85 is great for making power and burning cooler. I only mentioned it to let you know that I have them on my FBO + nitrous car which is driven N/A most of the time and it Dyno’d at 469 rwhp/434 rwtq on those plugs. Given that you’re never going to run forced induction, save yourself the time and money and stay with the factory plugs.
When you do tune, please come back and share your exact mods and Dyno sheet for comparison to see if you’re still in the same ballpark for power on the factory plugs.
kellyreno
S.C.
Dal
2021 Mach 1
If E85 runs cooler, would u not want a hotter plug?
NGOT8R
Adrian
2019 Bullitt
A hotter plug will increase the risk of detonation. In my case, I actually have 6* of timing pulled for nitrous, but timing is also added back in on the E85 tunes and it still runs great. It’s always better to play it safe than sorry. I’d leave power on the table any day over risking engine reliability.
kellyreno
S.C.
Dal
2021 Mach 1
Makes sense
