Best Boost Gauge T location
madlag
Snake Charmer
NC
2018 GT350R, 2022 GT500
As the title suggests, I'm looking for the best (most accurate) spot to T into vac/boost for a manual boost gauge. Running a pro-charger.
Jay-rod427
Kansas
2016 GT C/S
Any of the vacuum lines that are connected after the throttle body, and not after a check valve. Did you use the procharger vaccum manifold for the bov?
madlag
madlag
Snake Charmer
NC
I haven't gotten that far yet. I just installed the OPG/CS. I have the upgraded intercooler and large open bov; not sure if it uses the manifold vac or not at this point.
Jay-rod427
Kansas
2016 GT C/S
The bov, and boost gauge both need to see vacuum and boost. not sure about the gt350 specific kit or instructions, but it should come with a manifold and where to locate it. There will be other non vacuum lines like for the pcv system, but those are separate as they don't see vacuum/boost.
madlag
madlag
Snake Charmer
NC
Yea I just read ahead and found the recommended location in the book for where to put it. Thanks for the pointers.
