BBK header install help
Spykexx
Quad Cities, IA
2021 Mach 1 VMP Odin, 2025 Mach-E
shorties aren't too bad. Set aside plenty of time. The bottom bolts can be a bitch so make sure you have some swivels and extensions. The long tubes were a pain in the ass.
bizkitlimped
2016 shadow black V6 6spd
the passenger side is the worst...most of the nuts come off the studs, but if the bottom left nut comes out with the stud, you need to get the nut off the stud and put the stud back in the block because you cannot put the stud in after you try to get the header on.
get a set of wratchet wrenches that do not swivel...i had a set that swiveled and it was a pain in the ass to keep the wratchet on the nuts. Bring a lot of patience and with two people it should take you around 3-5 hours give or take. overall it's not as bad as i had expected it to be...but some of the nuts are a pain in the ass to get on.
most of the nuts and everything can be reached from the bottom of the car. you can choose to unbolt the starter if you wish, but it isn't necessary.
jperls
jperls
Thousand Oaks
Jason
2015 Magnetic Metallic V6, 1970 mustang convertible
Any tips or tricks for installing the passenger side? I have ratchet wrenches that do not swivel. What other tools do you recommend that I use? Sorry if this seems repetitive, but the instructions from BBK SUCK!
bizkitlimped
Use of swivels and extensions will be your savior, most bolts you can reach from the bottom. It seemed easiest that way. You can unbolt the starter to give more room,but it is not necessaryto do so.
2015V6Fla
2016 Mustang GT PP Premium MT6
Spray everything the day before you do the work with PB Blaster or something like that.
Remove the starter because it makes sliding the passenger side in a lot easier.
Patience is key. It took me about 5 hours by myself. Good luck!
jperls
jperls
Thousand Oaks
Jason
I still have not had time to install them yet...too hot up here in Sacramento and I am still unsure if I have all of the proper tools.
Here is what I think I need for the install that I currently have:
1. 13mm ratchet wrench
2. 1/2in 13mm socket
3. PB Blaster
4. ½in 15mm socket
5. ½in 17mm socket
6. ½in 18in extension
7. 2 ½in 6in extensions
Am I missing anything...any other tools that I should get that might help make this easier?
Mootang
Sacto, Caliunicornia
Henry
2017 Mustang GT
3. PB Blaster
4. ½in 15mm socket
5. ½in 17mm socket
Dude, its like an oven here this whole week and this weekend. I can't even touch my stang since a week ago lol.
2015V6Fla
3. PB Blaster
4. ½in 15mm socket
5. ½in 17mm socket
Here's a link to my report of my BBK header installation. I listed the tools that I used. Good luck!!
http://www.mustang6g.com/forums/showthread.php?p=1779691#post1779691
Jon|3.7
Houston, Tx
15' 3.7 Mustang
curious, could i change the mid pipe on shortys like long tube have catted h pipe/xpipe?
jperls
jperls
Thousand Oaks
Jason
Im not sure...I imagine it is possible...but I don't know.
My setup is a little different than most in that I did a resonator x-pipe delete and magnaflow magnapack mufflers. Everything is welded.
