Battery box and clamp
FAB Cruiser
Bucks UK
David
Mustang GT 2017
I had to remove the plastic clamp in order to change my battery. When I went to put it back in, the female threaded part under the battery box has moved, so I can't tighten the clamp. It looks like I need to remove the three bolts at the base of the battery box to get at it. Before doing that, I wanted to check those bolts won't also end up with nuts dropping inside, which would then requiring me to remove the wheel arch cover to get at the underside?
Thanks
David
TonyT930
Philadelphia, Pa.
Tony
2017 Mustang GT Convertible in Ruby Red
They are bolts, no nuts. I have my battery tray out when I ran a 4 gauge power wire to the trunk for 2 amps
TonyT930
Philadelphia, Pa.
Tony
WItoTX
Houston
Kyle
'17 GT350
You will be fine. I forget what holds the bottom ones, but I removed mine and no issues getting it back on.
