average cruise afr's on e85
v8440
AL
2016 gt
Hi all,
For those of you running e85, what do your afr's average according to your dash display when you're just cruising along? My car is stone stock other than the tune, and I'm seeing afr's bounce around from 10.1 to 10.6 or so. That seems a little rich to me for such a low load situation.
cbrtrx
tampa fl
2016 mustang gt
Stoich for e85 is 9.8/1. If you have a flex tune though it can differ depending on ethanol content and other variables.
dev1360
STL
DIB 2016 S550
^^^ This. Your car will idle and cruise at the stoich of whatever fuel you're using. Or as close to it as possible. E85 is 9.8. It's pretty hard to find true 85. E70-77 is about 10.2-10.1.
You're normal, nothing to worry about.
v8440
AL
2016 gt
Damn, I was hoping it could be leaned out some. Mileage, especially in the city, is pretty bad. We're talking 10 to 11 mpg here. Highway mileage is low 20s.
1badrz28
Woodbury, MN
I would be happy with that mileage.
Derek@Lethal
Wellington, FL
Derek
2012 Mustang GT 300A w/ Brembo's
That is also normal on ethanol as roughly 30% more volume is needed to create the same heat energy as a gasoline based fuel.
v8440
AL
2016 gt
For cruise conditions only, on e85 only, what would be the consequences of leaning it out close to the point of misfire? I wouldn't think you'd burn anything up, including the cat converters, because the ethanol burns so much cooler than gasoline.
