Possible upper strut mount or sway bar end links loose.Anyone know what is causing this noise?
Recently had BMR Sways, Adjustable Endlinks, Rear Cradle Kit, Camber Plates, and Steeda Alignment bushings installed by a reputable dealer and this sound started occuring.
I see..were these defective or just improperly installed?Turns out to be the camber plate on the driver side and endlinks on the passenger side.
Good luck and keep us updated buddy.Thanks for posting this.
I've been having a very similar noise from the both the right and left front suspension since I installed springs and camber plates. I've already tried buzzing each spring perch nut at the top of each strut with my impact gun a few times but that didn't help. Had the car up in the air and just started grabbing and shaking front suspension parts to see if there was any play without luck too.
I had given up on figuring it out and had almost relegated myself to just putting the stock spring perches back on. But now I think I'll try tightening everything under there first, starting with the end links. Thanks for the inspiration.
