Another square setup question
Quesever
2006 MX-5, 2016 BMW R1200R
I'm planning on buying the GTPP, and would like a square setup. Will the front 19x9 wheel clear the brakes on the rear?
I don't plan on tracking the car (traction not a huge issue with more narrow tire) and want to use it as a daily driver, so I'd like to keep tire costs down.
Thanks for any input or suggestions.
Quesever
Quesever
The Torsen dif and 3.73 gears are what I like most about the PP. I also like the look of the wheels. Not to mention you need the PP for the magneride shocks
Chad11491
Roswell, GA
17 Lightning Blue GT Premium PP
You'd be better off getting a 19x9.5 or square 19x10 setup front and rear and going 274/40r19 square or 285/35r19 square. It'd be a shame to get such a nice tire package and then downsize it.
highvoltage
NorCal to SoCal
Brock
24 Mustang GT Atlas Blue, 23 Race Red Bronco
So just the basic GTPP for 2018 comes with the same 2015-2017 PP wheels. They are 19x9 front and 19x9.5 rear. IF you can find an extra set do that and run the 9.5 ones as your summer wheels with a 275 and then do the 9 ones for winter with a 255. Or just get a set of 19x10s like i just ordered. Gonna use the PP wheels for winter now.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Ya it should fit. I havent personally test fit a front on the rear but it should be fine. It may be /marginally/ farther inboard than the 9.5" PP wheel, but it should be ok.
Instead, most people are running the rear wheel in the front (with a small +5mm spacer for clearance). You can still run whatever tires would fit the 9" wheel, but they'll be better supported on the wider 9.5" wheel, and your options for going to wider 275/285 widths in the future is better with square 9.5" wheels vs square 9".
Labradog
Santa Barbara, CA
Jeff
2016 Mustang GT Guard Metallic
Brotha you're about to spend almost 50k on a car. I wouldn't be too worried about the cost difference between rotating tires and not. If you really want to keep the PP wheels I'd find some take off 9.5" to use up front like Chad11491 suggested (or better, go aftermarket)
Paul@PKAUTODESIGN
The Wheel guy
Los Angeles, California
WWW.PKAutoDesign.com
Paul A.
2016 Shelby GT350 Tech Pack #G5531 Avalanche Grey
You can go lightweight square with wider footprints with no problems as a cost effective route.
highvoltage
NorCal to SoCal
Brock
See Paul for sure when it comes to wheels. Got mine from him. Very knowledgeable and very helpful.
Paul@PKAUTODESIGN
The Wheel guy
Paul A.
