Square setup questions
Cardude99
Phoenix, AZ
Sam
2018 Ecoboost
Can you do 19 x 10 with a 35 mm offset square set up on an 18 ecoboost, PP with mag ride? Will it work and look flush? When I change wheels in the future I would like to stick with a square setup. Also looking at 285's all around as well. I am also looking at the P51's due to cost and weight savings.
Oh and does anyone know what the 2018 ecoboost PP wheels weight?
Competition Orange
Columbus, Ohio
2017 GT350
You won't get a flush fit front AND back with the same offset wheel. You'll need spacers out front to push the wheel out a bit compared to the rear.
Cardude99
Phoenix, AZ
Sam
2018 Ecoboost
Will it look odd without spacers? I would prefer to not use them.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Nah, its fine w/o spacers up front on a 19x10+35 w/ 285s. The rears will be very flush and the fronts will be ever so slightly tucked, but still a lot more flush than the stock front wheels. I'd hazard a guess that the vast majority on that wheel offset don't run any kind of spacer up front.
You're good to go.
S550MG
Alabama
2016 S550
I run this exact setup and it looks really good and aggressive. The rear stance is perfect and the front is ever so slightly tucked but still much better than stock. I added a 7mm spacer up front just to make it perfect. No rubbing with 285/35’s on Steeda ultralight linears.
